need help tapping into power for video
Old Jun 9, 2007 | 07:40 PM
rage777's Avatar
can anyone help me with electrical? i have a 7" video monitor that needs to connect to 12v power source. i have no clue where the best place would be to tap into. fusebox? acc. power? where? how? any help would be greatly appreciated. thanks.
i have looked in the forums and can't get a definitive answer or how to.
Old Jun 10, 2007 | 04:22 AM
rage777's Avatar
nothing is beyond my skill. i just want to connect to switched 12v power. i don't want to just start sticking wires in the fuse box unless i have a good idea where to put them and how. instead of being a smart ass, maybe you could have given me an answer and not waste our time being a douche. thanks anyway. anyone one else that can be more helpful?
Old Jun 10, 2007 | 12:38 PM
rage777's Avatar
some of you like to talk in circles without actually getting to the topic at hand. it has nothing to do with skills. i lack the KNOWLEDGE, not the SKILL. with the information that i gave you, 12v switched power connection, you couldn't help me out? it seems you are lacking the skill to be nice enough to fellow fitfreak members to actually help them. when you realize what being a part of society means, go ahead and give me some information, if you can. if you can't/won't help, don't bother responding as it wastes time.
can i stick a wire into the positive side of a fuse? do i stick it into a wire harness? do i splice in to a wire somewhere? i just a simple location and how to. that's all i need so i don't damage equipment.
Old Jun 10, 2007 | 01:52 PM
rage777's Avatar
acc. power. i want it powered the same as the radio. or the socket. maybe i'm mistaken, but isn't that what switched 12v power is? it's not constant. it's on when the ignition is SWITCHED on.
maybe you could try saying something like:
if you want it to be powered all the time, do this.
or
if you want it to come on with your 12v socket do this.
that's how normal people interact. and you're a moderator? do you consider yourself to be helpful being that way?
i just want to have my monitor come on when i turn the ignition to acc.
Old Jun 10, 2007 | 02:35 PM
rage777's Avatar
thanks for your non-help. you may not be a welder, but someone could tell you how to do it. obviously you think this is rocket science no one could possibly understand. when you have difficulty understanding something, have you ever asked for help? i'm sure the answer is a simple one yet you still refuse to give me a decent helpful answer. thanks for wasting my time.
Old Jun 10, 2007 | 02:46 PM
07FitSportNJ's Avatar
Disclaimer: The following is provided as a GUIDE ONLY, and neither myself, nor FITFREAK.NET endorse, recommend, encourage nor take any responsibility for the outcome of someone else doing the following. You follow these steps at your own risk!
Here you go:
12volts white (50A) + ignition harness
Starter black/white + ignition harness
Second Starter N/A
Ignition black/yellow + ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory yellow/black + ignition harness
Second Accessory white/red + ignition harness
Keysense green/white - ign harn or GCM, 40 pin plug, pin 11
Notes: The GCM (Gauge Control Module) is incorporated in the instrument cluster.
If equipped, also found at the SCU (Security Control Unit) under the driver side dash, 20 pin plug, pin 8.
Power Lock white/green - dr kick or GCM, 40 pin plug, pin 9
Power Unlock white/blue - dr kick or GCM, 40 pin plug, pin 10
Lock Motor white/black 5wi fuse box, green 8 pin plug, pin 2
Unlock Motor yellow/black 5wi fuse box, green 8 pin plug, pin 5
Parking Lights+ red/black + fuse box, 14 pin plug, pin 5
Parking Lights- blue - switch or GCM, 40 pin plug, pin 19
If equipped, also found at the SCU (Security Control Unit) under the driver side dash, 16 pin plug, pin 5.
Hazards same as turn signal wires
Turn Signal(L) green/red + switch or GCM, 20 pin plug, pin 6
Turn Signal(R) green/yellow + switch or GCM, 20 pin plug, pin 5
Reverse Light green/black + fuse box, 14 pin plug, pin 9
Door Trigger green (D), purple (P) - kick or GCM, 20 pin plg, pins 14, 13
Notes: Use both wires and diode isolate each.
If equipped, also found at the SCU (Security Control Unit) under the driver side dash, 20 pin plug, pins 20 and 9.
Dome Supervision green/red - fuse box or GCM, 20 pin plug, pin 12
Trunk/Hatch Pin green/red - dr kick or GCM, 20 pin plug, pin 16
If equipped, also found at the SCU (Security Control Unit) under the driver side dash, 20 pin plug, pin 7.
Hood Pin green/black - pin sw or SCU, 20 pin plug, pin 18
Notes: The SCU (Security Control Unit) is under the driver side dash.
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm white/red - dr kick or SCU, 20 pin plug, pin 4
Notes: Meter this wire while turning the key in the driver door key cylinder.
Factory Alarm Disarm white - dr kick or SCU, 20 pin plug, pin 3
Disarm No Unlock see factory alarm disarm
Tachometer green/orange ac fuse box, 6 pin plug, pin 2
Notes: Can also go to any fuel injector and use the wire that is NOT yellow/black.
Can also go to any ignition coil and use the wire that is NOT black/white or black.
Wait to start N/A
Brake Wire white/black + sw or fuse box, 14 pin plug, pin 4
Parking Brake green/orange - switch or GCM, 40 pin plug, pin 3
Horn Trigger orange - switch or GCM, 14 pin plug, pin 8
If equipped, also found at the SCU (Security Control Unit) under the driver side dash, 16 pin plug, pin 2.
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Transponder
Part #: 1100F
Alternate Part1 #: 1100X
Alternate Part2 #: 556HW
Alternate Part3 #: 556UW
Alternate Part4 #: DesignTech 20402
Alternate Part5 #: DesignTech 29402
Notes: Standard on all models. When using the 1100F or 1100X, a software change to 1100HA is needed. When using the 556HW, follow the mode 1 wiring diagram. The reference wire is brown/yellow, data wire is lt. green/black and ignition wire is black/yellow.
Smart Starter Kill Relays: Not Available
This wiring information is being provided free of charge on an "as is" basis, without any representation or warranty. It is your responsibility to verify any circuit before interfacing with it using a digital multimeter.
Directed Electronics assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information.
Old Jun 10, 2007 | 02:56 PM
rage777's Avatar
wow a human being! thank you for the info. i really appreciate the help.
Old Jun 11, 2007 | 05:02 AM
CuTeBoi's Avatar
All this information was in your manual.....
This was just someone copying and pasting from someone else who decided to pick at the manual.
maitusents
rawr.
Old Jul 1, 2007 | 02:09 PM
timot_one's Avatar
Good info 07FitSportNJ. All that was in the owners manual? I'll have to crack that bad boy open as soon as I get my hands on one.
rage777, you've got to remember that there's more than one way to get 12 volt power. The answer you desire depends on how you want it to act. You can have your monitor on all the time, when you turn your car on, when you turn your stereo on, when you use your left turn signal, and on and on ad nauseum. claymore was just asking for more information so he could give you an appropriate answer.
Old Jul 1, 2007 | 07:10 PM
no its not in the owners manual, I got it from a dealer only web site for aftermarket alarms and stuff that I have acess too.
Old Jul 1, 2007 | 10:51 PM
timot_one's Avatar
I had a feeling that that info wasn't readily available without a Haynes manual, or some sort of insider info. Good info though. I'm sure your post will be helpful to a lot of people.
Old Jul 2, 2007 | 12:17 AM
CuTeBoi's Avatar
it's in one of the 4 manuals i got from my dealer... it's in the repair manual.
Electrical section.
RavenManiac
Dec 28, 2017 12:58 PM
Fitcious
Aug 2, 2010 09:23 PM
psycho
Jun 11, 2007 01:16 AM
RomeoJunior
Jan 29, 2007 05:15 PM
John W. Barron
May 4, 2005 04:44 PM
