question on coolant..
Old Jun 18, 2007 | 12:10 AM
Batman's Avatar
umm.. so. my dad checked the coolant box thingy on the fit and told me to top it up. he said its like 15% above min. mark, but not on the max mark. i just never checked cause its relatively a new car. should i fill it up to max? thanks.
Old Jun 18, 2007 | 12:30 AM
grouser's Avatar
i always do like my dad says,,,go to the max line it wont hurt a thing
Old Jun 18, 2007 | 12:34 AM
Batman's Avatar
im just curious why for a new car with 11000km, just one oil change so far, im already seeing coolant loss. im scared
Old Jun 18, 2007 | 01:13 AM
Batman's Avatar
i just checked the manual.... it says to fill up only halfway... i guess a little bit low is acceptable...
Old Jun 18, 2007 | 05:22 PM
07fitsport's Avatar
anyone put some wetter than water or thought of running cooler thermostant since the cooling capacity on the fit is sooo small??
Old Jun 19, 2007 | 03:02 AM
redfit_pr's Avatar
spoon low temp thermostat? please give me more info about this and it will help in what?
Old Jun 19, 2007 | 09:20 AM
07fitsport's Avatar
i come from american cars and truck world where cooler is better to a point using such things as lower temp thermostats, using more coolant and trying to keep the intake cooler..usually cooler engine runs more performance and mpg u get
i know the intake on the fit sport get crazy hot at least mine does.....
would reducing the intake manifold temp help with fuel economy or performance??? and what would you use i was thinkin of like a heat shield or so..
Old Jun 19, 2007 | 11:28 AM
grouser's Avatar
The problem with a lower temp thermostat is the computer still tries to get the temp of the engine up to the original setting,,when it can't get there it thinks the engine still needs more gas (like haveing the choke on untill it warms up),,that's what gives you the poor gas mileage, it also clogs the coverter cuz your running rich all the time and idles like crap...leave the thermostat alone IMHO, there's more to it than just changin one part,,,
Old Jun 19, 2007 | 06:20 PM
grouser's Avatar
To be quite honest I was goin off my 86 GMC Jimmy,(not a very good comparison obviously!!!) I put a 180 instead of the OEM 210 and it ran rich as heck,,,I should have stated this and my limited knowledge of the subject. Thanks for giving us the REAL scoop , as you are much more familiar wlith the Fit than I am,,,my bad,,,,
Old Nov 23, 2007 | 01:21 PM
andy27's Avatar
I've had my fit for about 3 months/4000 miles and I just happened to look at my engine coolant last night and it was just above the minimum! then this morning I checked and it was already under minimum! is that normal that I'm already out?? I feel like I haven't had the car long enough for that to run out!
Old Nov 23, 2007 | 04:52 PM
kndlewis's Avatar
When the engine is cold (off) the coolant bottle will be just above minimum line. When the engine is hot, the coolant fills the bottle and as the engine cools down, it is drawn back into the system.
Go ahead and fill it if you want but don't be surprised when you check it in a few days and find it low again. If the bottle is full when cold, it will overflow (out the overflow tube) when hot.
Old Nov 25, 2007 | 02:22 PM
sortanewinatl's Avatar
the coolant is mostly water... it expands as it heats up, so when it's cold it should be, more or les, at the min line... nothing to worry about.
Old Dec 1, 2007 | 05:54 PM
fm2n's Avatar
I fill mine half way. I have always thought that it was a reserve in case the radiator needs more. As it turns out, its an overflow reserve tank for expansion when it gets hot.
Wreck Ignition
Mar 14, 2024 03:24 PM
doctor J
Jan 23, 2019 03:02 PM
spookyneo
Nov 20, 2017 12:05 AM
Crisu
Mar 16, 2013 05:12 PM
mmdir2002@yahoo.co.uk
May 4, 2005 04:44 PM
