Honda fit with turbo...Lost the Waranty?
Old Jun 25, 2007 | 05:58 PM
sansar's Avatar
Hi, I wanted to know if a buy and install a turbo to my honda fit i can lost the warranty of the Motor...
It Doesn't matter if the turbo only give me 200 HP? with 200HP the motor is not in damage.
Old Jun 25, 2007 | 06:34 PM
phil_qc's Avatar
Are you serious ? A turbo is about the maximum
abuse you can do to a motor... You warranty
will be void for sure.
Philippe.
Old Jun 25, 2007 | 06:38 PM
Illusive's Avatar
will be void for shure.
Philippe.
Yeah, adding a turbo will void the warranty for sure...heck an intake is pushing it!!
Old Jun 25, 2007 | 06:43 PM
sansar's Avatar
mmmmmm. What is the maximum upgrade that i can make for the car without avoid the warranty?
Old Jun 25, 2007 | 06:55 PM
phil_qc's Avatar
light wheels, tires, weight reduction, intake & exhaust, stereo,
look, suspention, synth oil ...
Philippe
Old Jun 25, 2007 | 06:57 PM
sansar's Avatar
pufff. thats sucksss....
Nitro?
Old Jun 25, 2007 | 07:33 PM
arsonall's Avatar
here's the thing (at least in the US). there is nothing that says this voids your warranty, that doesn't. a warranty claim can be rejected if the cause of the failure was due to the aftermarket part.
if your window winding motor breaks under warranty, an intake can't possibly be the cause of the defective window motor, so that defective part would be covered.
if you add anything that "could" cause damage to your motor. you better believe honda will say it was caused by the aftermarket part.
with my wrx, i was told a CARB legal intake and cat-back exhaust were the only safe bets on power mods.
Old Jun 25, 2007 | 07:48 PM
fazzster's Avatar
You will never get 200hp with just a turbo......130hp at best. You are better off doing an engine swap or just getting a Civic Si
Old Jun 25, 2007 | 08:25 PM
sansar's Avatar
The car is like a computer. the best computer is the computer that you assembly. in the car is the same. and its less expensive. And many people doesn't have it.jejeje.
Old Jun 25, 2007 | 10:00 PM
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
Please tell me that was a joke right? Theres a member on here that dynoed 198whp on spray and bolt ons. All you need is more boost with a bolt on turbo kit. Its all in the tuning.
200whp is very do-able with the L15. Race gas, 15psi and a good tune. Id say OVER 200whp.
Adding a turbo will void all engine/drive train warranty. Bumper to bumper should still be covered (depending on the part).
Philippe
Depending on the dealership they will void certain warranty areas with these parts. Intake and exhaust, anything that is associated with the intake (sensors, "TB" < Id know. Hahaha!). They will charge you for diag when having mods. If the car was stock you'd save that $50-$100.
Suspension can void drive train warranty. It all depends on the dealer.
You can run nitrous if you wanted. If something happens be sure the install is clean and easy to remove. Dont leave any traces or signs of you having nitrous.
If you want, go to the dealership you have in mind. Tell them what you plan on doing and ask if the warranty will still apply. If they give you a thumbs up get it in writing!! A signed piece of paper is good enough.
Old Jun 25, 2007 | 10:32 PM
fazzster's Avatar
MX6GT89,
Sansar wrote about installing a turbo kit. I interpret a turbo kit consisting of a bolt on turbo, engine management, and intercooler like a Greddy kit. This would achieve approximately 30 hp at the flywheel. I do believe you, that the Fit motor can achieve 200hp but this would most certainly involve much more than a "turbo kit" (pistons, flywheel, porting, cam, larger injectors etc..)....either route would most certainly void the powertrain warranty.
Old Jun 26, 2007 | 11:40 AM
sansar's Avatar
MX6GT89,
a turbo kit include all this
A&J Racing :: Engine :: Fit/Jazz (GD3/4) :: T1R TURBO Kit - Honda Fit 07-up GD3
Old Jun 26, 2007 | 08:42 PM
doctordoom's Avatar
Supervillain
MX6GT89,
you can easily turn out LOTS more hp just by turning up the boost and tuning. most turbo "kits" are for 7 lbs boost. you can turn it a lot higher than that for a lot more hp, but risk to your engine would then skyrocket without the proper tuning and internals.
Old Jun 26, 2007 | 11:08 PM
Posts in the NUUDE
MX6GT89,
Yes! Im sure hes talking about a bolt on turbo kit. I dont think they make a bolt on kit that doesnt include injectors and other fuel mods.
200+whp is doable without internal work. I know it. If D16's can do it, why cant the L15? I honestly think the OEM clutch will hold it too.
Just because it says it runs 7psi as it being a bolt on kit doesnt mean thats what its limited to. Any turbo can run more boost. It all depends on the size of the turbo of course. Pushing too much boost on a small turbo will be turning hot air. Basically a spike of good power than a fall. My Mx6 came with a TINY turbo. I ran 17psi on that turbo daily.
Old Jun 27, 2007 | 03:29 AM
aywwsd's Avatar
Senior Member
the real joke here is you implying 200whp is the norm with turbo fit with a good tune.
good tune isnt a miracle. stock fit have 75whp, you are not tripling the hp with a just turbo kit.
Matt Van Riper
Jun 9, 2019 06:33 AM
mikeGe82012
Apr 17, 2015 02:11 PM
gynosis
Jul 13, 2010 10:39 AM
tumbleweed80
Dec 15, 2006 10:27 PM
southwilrise87
Jul 23, 2006 01:39 AM
