car audio sound
Old May 4, 2005 | 11:16 AM
vp4life84
Guest
Posts: n/a
car audio sound
hi, i have a problem with my car stereo audio. everytime i turn up the
volume, the volume of the speakers goes down. i accidentally had the
ground wire touch the memory wire, would that be the cause? if it is, does
anybody know how to fix it? please help!!!
Randolph
Guest
Posts: n/a
Re: car audio sound
Give us a little more to work with here, Car model and year, factory or
after market stereo, any particular noise or distortion in the sound, or
is it just the volume that is the problem?
Most Hondas have a fuse in the fuse box under the hood (not the one
under the dash) where there is a fuse marked "Backup". This fuse is for
the ECU memory, the clock and the memory wire to the stereo. When you
shorted the memory wire to ground, you that fuse probably blew. Not that
it necessarily will fix your particular problem, but try replacing that
fuse. It is a regular automotive fuse, usually 7.5A (but check inside
the cover of the fuse box to be sure of the rating).
A very modest collection of Honda tech info can be found at:
http://www.geocities.com/ng_randolph
Andrea Prosser
Apr 15, 2019 08:40 AM
chadew
May 13, 2011 04:22 PM
stock0891
Feb 20, 2010 04:06 AM
struct32
Jan 3, 2009 12:12 PM
SaraKat
Aug 22, 2005 11:30 AM
