front marker lights:wiring question
Old Jul 8, 2007 | 08:00 PM
jman245's Avatar
i was wondering why there are so many wires to this light.there are two pair of wires,one set of black for the ground i think and one set of red wires for power.why are there two wires for them each.i want to wire up some side markers but got confused when i saw this.someone please help me.i want them to go on with my front markers and also signal too.
Old Jul 9, 2007 | 12:41 AM
quangalang's Avatar
wait are there 2 wires or 4?
Old Jul 9, 2007 | 03:10 AM
j5ive's Avatar
The wires you want are red/blk for the parking lamp +ve, and grn/red for the left turn signal +ve, and grn/yel for the right turn signal +ve.
Connect one end of the side marker to the +ve of the parking lamp, then the other side of the side marker to the +ve of the turn signal on its respective side. When the parking lights are off, the side marker will flash in sync with your turn signals. When the parking lights are on, the side markers will flash alternate to your turn signals.
Good luck.
p.s. - aside from the red/blk wire for the parking light, there are three other red/(colored) wires on each side for the H4 bulb. Two wires feed power to each filment, and the one leaving is not technically a ground since our cars are switch grounded, thus it's not blk.
Old Jul 9, 2007 | 06:20 PM
jman245's Avatar
there are a total of four,2 red and 2 black for each marker light.
Old Jul 9, 2007 | 06:23 PM
jman245's Avatar
Good luck.
u didnt answere my question,i wanted to know also why there are 2 red/blk wire for each marker light that are abouve the headlights.there are also two black wires i guess is ground.if i splice the red/blk wire,do i do both?
Old Jul 10, 2007 | 05:29 AM
j5ive's Avatar
No. if both red/blk wires are terminating at the same contact point, then it will not matter which one you splice into since they'd be touching each other anyway at the plug. Use a tester if you want to be sure.
My guess regarding the duplicate set of wires is because JDM headlamps actually have two separate bulbs for the parking/position lamp. One on top of the headlight like our cars, and one on the side. Honda probably just wanted to use the same wiring loom going to the headlight assembly for all markets to save cost, and just terminated both sets of wires at the one bulb for USDM models.
andre181
Nov 24, 2017 06:59 PM
WhEreZmYFiT
25
Mar 21, 2016 06:20 PM
B-Blue
Apr 6, 2010 04:28 PM
jman245
Jul 21, 2007 03:30 AM
Dave Boland
Aug 1, 2005 11:52 PM
