Fujita SRI and Idle relearn
Old Jul 9, 2007 | 11:55 PM
Whitehybrid's Avatar
Anybody with the fujita sri have to, or did, the idle relearn? just wondering since the t1r suggests it, but i was unclear on how exactly to do it, or if i even should with the fujita intake...
I just installed it tonight, and WOW its loud and deep...completely satisfied with it...pulls a little harder, nothing crazy, but i can notice...
Old Jul 10, 2007 | 12:09 AM
phil_qc's Avatar
Could you tell me more about the coolant hose ?
Does the fluid leak if the engine is totaly cold ???
Thanks,
Philippe
Old Jul 10, 2007 | 12:16 AM
Thanks,
Philippe
yes, no matter hot/cold your fluid will come out because you are removing a soft line from the block...you are only replacing your stock hard lines because the coolant hard line gets in the way of the SRI...
just take off the stock line, plug the outlet with your finger, then install the rubber line...use cardboard under your car to catch any fluid...because if you don't cap it off with your finger it will spill everywhere...
Old Jul 10, 2007 | 12:19 AM
phil_qc's Avatar
Thanks...
Philippe
RuffleFIT's Avatar
In the process of oredering one.
Thanks for the tips/tricks.
Old Jul 10, 2007 | 12:44 AM
George02's Avatar
Im not sure??? I just let my car run for a little while then drove it around, its a cool intake for now?
Old Jul 10, 2007 | 12:57 AM
Fit of RAGE's Avatar
Idle relearn is:
Turn ALL accessories OFF (Defrost, A/C, Radio, headlight)
With Park Brake on, start vehicle
Wait for cooling fan to cycle (on AND off) 2 times
Ciggy
Nov 7, 2010 01:04 AM
Luichenwai
17
Jul 23, 2009 10:21 PM
AnlDyxp_GD3
Dec 27, 2008 11:43 PM
sam21
theljnet.com
Apr 21, 2008 12:09 AM
gettinafit
27
Jun 7, 2006 03:57 PM
