um.....wtf
Old Sep 17, 2007 | 08:31 PM
Crawly's Avatar
um.....wtf
Ok, I got eberything installed, but my new radio won;t remember the presets. In other words, you save stations, turn the car off and back on and they're gone. I'm having a brain fart here....what am I missing?
Old Sep 17, 2007 | 08:57 PM
xwikedonex's Avatar
sounds like your 12v constant(battery+) and acc(key on) wires are backwards switch them and you should be set
Old Sep 17, 2007 | 09:25 PM
Injundon's Avatar
You blew the fuse for your constant wire (+12V memory) Check your fuses in the fuse box under the hood..not the one in the car.
Old Sep 17, 2007 | 09:29 PM
Crawly's Avatar
I pulled the radio out and checked the wiring and everything looks fine. I'll check the fuses next. The presets for the radio and Sirius are stored on the radio right? I'm asking because my Sirius is wiried to the accessory socket (since I never use it) and I know it doesn't get constant power. The factory radio had three connectors on the back, could my constant be on one of those instead of the yellow I'm using?
Old Sep 17, 2007 | 09:32 PM
Injundon's Avatar
if you bought a wire harness for your car, the yellow wire would be the correct one. If your sirius unit is the alpine one then it needs constant power to operate properly. Your aloine head unit turns it on and off when you select it as a source. If it's an aftermarket portable one then it should be hooked to ACC
Old Sep 17, 2007 | 09:40 PM
Crawly's Avatar
The sirius seems to be working fine, aside from the memory loss problem. The fuses under the hood and in the car look fine. So basically you'rer saying the sirius and HD have nothing to do with the memory being lost on the radio right?
Old Sep 17, 2007 | 09:45 PM
Injundon's Avatar
Nope.. do you have a test light or multimeter?
Old Sep 17, 2007 | 10:27 PM
Crawly's Avatar
Success!! PM Sent.
Old Mar 15, 2020 | 02:35 AM
TheTickingGE8's Avatar
Uh
Originally Posted by Crawly
Success!! PM Sent.
what ever happened I’m fighting with the cords reversed them red/yellow yellow/red and tmw am going to look at my fuses my radios doing this too as well as not saving how low I have the volume so when I turn it on it about makes me shit myself every time.
Fit freak242
Nov 6, 2013 10:44 PM
setter11
Oct 31, 2010 03:35 PM
dickiez
Apr 4, 2010 12:09 AM
Fit of RAGE
Sep 24, 2009 10:32 PM
Crawly
Sep 12, 2007 09:41 AM
