Sponsored by:
Sponsored by: CARiD
Just another steering wheel question
Old Oct 3, 2007 | 12:03 AM
byebyepanda's Avatar
I'm going to buy a MOMO steering wheel soon and the hub adapter that would go with my car. I was wondering if that's all I needed to use my steering wheel? Unlike other mechanisms like NRG, where you have to buy a short hub and quick release. Thanks!
Old Oct 17, 2007 | 11:51 PM
aallbbeerrtttttt's Avatar
NRG Innovations does not require you to purchase short hub and quick release. The NRG Innovations short hub is no different than a Momo hub, other than the fact that it's, well, short. The reason it's short is designed for users that like to use a quick release, so it doesn't space it out as far and gets in the way of some drivers chests.
With that out of the way, at the very minimum to install a new steering wheel onto your car, you would need:
-Steering wheel hub adapter
-Steering wheel with same bolt pattern as hub
There are also other parts you can add on for more features:
-Quick release to allow removal of steering wheel
-Quick release lock to protect others from popping the same style quick release onto your car
-Hub spacers so you can have the steering wheel sit closer towards you
Keep in mind, you will throw the airbag light on the gauge cluster unless you wire in a resistor or something else and if you have sport model, you'll lose the cruise control feature unless you rewire also.
I can order you NRG Innovations, Momo, Sparco, Personal, or Nardi parts.
Fit_Mike
Sep 6, 2012 09:47 PM
413FIT
Jan 21, 2011 05:08 PM
im the fit
Aug 17, 2009 09:10 PM
VTECJunkie
Jul 22, 2009 04:56 PM
jdm_gd
Feb 23, 2009 11:51 AM
