Accord 91 undrivable in the rain
Guest
Posts: n/a
Re: Accord 91 undrivable in the rain
On 30 Apr 2005 03:48:23 -0700, "SadaYama" <gireesham@yahoo.com> wrote:
>Apart from setting A/C on and setting it towards windshield, you need
>to play with the heater dial to full heat or half or little.
And recirculate OFF. You don't want to be using air that has extra
moisture in it from your own breath. You want outside air.
Guest
Posts: n/a
hmm. and I thought it was the other way around. I thought you wanted
recirculate ON so that you are not pulling moisture out of additional
outside air. Also, I thought that having the defroster on and the A/C did
the trick.
Scott
"John Ings" <nodamned@spam.org> wrote in message
news:9du671tb11tja95d9vtvr6e1a7avjog0gg@4ax.com...
the trick.
Scott
Guest
Posts: n/a
On Sat, 30 Apr 2005 14:28:17 -0500, "Scott Van Nest" <JohnDoe@cox.net>
>outside air.
Try it sometime, see which works better.
>the trick.
Depends on how high the humidity is and the outside temperature.
>outside air.
>the trick.
Guest
Posts: n/a
news:10p771drt0ur933kj6tmp1odo41t7qc2rs@4ax.com...
>>outside air.
>>the trick.
Usually, if it's summer and it's raining, the humidity is pretty high
outside ;-).
I use the AC with defrost setting and recirculate. Many cars automatically
switch to recirculate and run the AC when you select defrost, but not my
Hondas.
I think the OP should check his/her car for rain leaks and possibly a
plugged AC drain line.
Ray
Guest
Posts: n/a
> Hondas.
I heard that newer Hondas work that way.
> Hondas.
Guest
Posts: n/a
No, newer hondas switch to outside air and turn on the the A/C when you
press defrost (and some of the older hondas too.... if they have automatic
climate control)
Also other brands of cars almost insist on outside air. I was in a 2000
dodge neon and when you turn the knob to defrost the recirc knob goes to
fresh.... it won't let you have recirc set and the defrost too.
"Imminent Vengeance" <me@privacy.net> wrote in message
news:1nxkd7sb5ynrn$.dlg@imminentvengeance.com...
>> automatically
>> Hondas.
climate control)
>> automatically
>> Hondas.
Guest
Posts: n/a
On 4/30/05 3:38 PM, in article 4oOdnS0LA-FIce7fRVn-hg@comcast.com,
>>> outside air.
>>> the trick.
> outside ;-).
> Hondas.
> Ray
I would be really surprised to find any car that automatically switches to
recirculate when you turn on the defroster. Most cars usually have a
comment in the owners manual that says something along the lines of "for
maximum defogging, turn the AC on and make sure recirculate is off".
>>> outside air.
>>> the trick.
> outside ;-).
> Hondas.
> Ray
Guest
Posts: n/a
In article <1114848392.452942.48490@g14g2000cwa.googlegroups. com>,
madrox99@hotmail.com says...
>The fog just makes the visibility TERRIBLE. The windshield and
>passenger windows will not de-fog.
>What are the correct A/C settings for summer rain?
Make sure you do not have the air set to recirculate. Than can cause
problems.
Alex
problems.
Alex
Guest
Posts: n/a
In article <s1Rce.629$HD4.610@okepread02>, JohnDoe@cox.net says...
>the trick.
Definitely not. You want outside, drier air, comring into your car. There
is quite a bit of moisture in your breath.
Alex
>the trick.
Alex
