Accord 91 undrivable in the rain
Old May 4, 2005 | 04:44 PM
madrox99@hotmail.com
Guest
Posts: n/a
The fog just makes the visibility TERRIBLE. The windshield and
passenger windows will not de-fog.
What are the correct A/C settings for summer rain?
SadaYama
Guest
Posts: n/a
Re: Accord 91 undrivable in the rain
Apart from setting A/C on and setting it towards windshield, you need
to play with the heater dial to full heat or half or little.
John Ings
Guest
Posts: n/a
And recirculate OFF. You don't want to be using air that has extra
moisture in it from your own breath. You want outside air.
Scott Van Nest
Guest
Posts: n/a
hmm. and I thought it was the other way around. I thought you wanted
recirculate ON so that you are not pulling moisture out of additional
outside air. Also, I thought that having the defroster on and the A/C did
the trick.
Scott
"John Ings" <nodamned@spam.org> wrote in message
news:9du671tb11tja95d9vtvr6e1a7avjog0gg@4ax.com...
John Ings
Guest
Posts: n/a
On Sat, 30 Apr 2005 14:28:17 -0500, "Scott Van Nest" <JohnDoe@cox.net>
>outside air.
Try it sometime, see which works better.
>the trick.
Depends on how high the humidity is and the outside temperature.
WaterWatcher
Guest
Posts: n/a
news:10p771drt0ur933kj6tmp1odo41t7qc2rs@4ax.com...
>>outside air.
>>the trick.
Usually, if it's summer and it's raining, the humidity is pretty high
outside ;-).
I use the AC with defrost setting and recirculate. Many cars automatically
switch to recirculate and run the AC when you select defrost, but not my
Hondas.
I think the OP should check his/her car for rain leaks and possibly a
plugged AC drain line.
Ray
Imminent Vengeance
Guest
Posts: n/a
> Hondas.
I heard that newer Hondas work that way.
Jafir Elkurd
Guest
Posts: n/a
No, newer hondas switch to outside air and turn on the the A/C when you
press defrost (and some of the older hondas too.... if they have automatic
climate control)
Also other brands of cars almost insist on outside air. I was in a 2000
dodge neon and when you turn the knob to defrost the recirc knob goes to
fresh.... it won't let you have recirc set and the defrost too.
"Imminent Vengeance" <me@privacy.net> wrote in message
news:1nxkd7sb5ynrn$.dlg@imminentvengeance.com...
>> automatically
>> Hondas.
E. Meyer
Guest
Posts: n/a
On 4/30/05 3:38 PM, in article 4oOdnS0LA-FIce7fRVn-hg@comcast.com,
>>> outside air.
>>> the trick.
> outside ;-).
> Hondas.
> Ray
I would be really surprised to find any car that automatically switches to
recirculate when you turn on the defroster. Most cars usually have a
comment in the owners manual that says something along the lines of "for
maximum defogging, turn the AC on and make sure recirculate is off".
Alex Rodriguez
Guest
Posts: n/a
In article <1114848392.452942.48490@g14g2000cwa.googlegroups. com>,
madrox99@hotmail.com says...
Make sure you do not have the air set to recirculate. Than can cause
problems.
Alex
Alex Rodriguez
Guest
Posts: n/a
In article <s1Rce.629$HD4.610@okepread02>, JohnDoe@cox.net says...
>the trick.
Definitely not. You want outside, drier air, comring into your car. There
is quite a bit of moisture in your breath.
Alex
TommyMadison
Oct 13, 2014 12:25 AM
Vince_TB
Jul 25, 2011 12:25 PM
pb and h
Sep 18, 2008 03:56 PM
sLiVeRwOrM
Jul 8, 2006 03:40 AM
Ben
May 4, 2005 04:44 PM
