Question about Subwoofer install
Old Oct 30, 2007 | 04:19 PM
zeemon's Avatar
Is it possible to set up an amp and subwoofers to the stock headunit? I have a rockford p3001 and a power cap to power 1 10" woofer. Would it be possible to set this up to the stock headunit? or what mods will i need to set this up?
peace
Old Nov 1, 2007 | 09:17 AM
jkg8706's Avatar
Yes, youll need a loc (line out converter)...it ties into factory high input speaker leads and converts it into low level rca's for an amp (available almost anywhere)...you tie it in behind the radio ... to get the radio out there is one phillips #2 screw holding the a/c shroud thingy on, pop that off and then there are two 8 mm screws up there holding the bottom of the radio WAY up there!...them the radio should pull out (it will be very difficult) I dont know the color of the wires you have to tie into but ill post back up with the info later on today but if i forget then continuiously check Car Alarm, Car Stereo, Mobile Video, and Cruise Control Info for Installers
payluder
17
Oct 7, 2014 09:10 PM
GeneralLee86
2nd Generation GE8 Specific Fit I.C.E. Sub-Forum
16
Feb 28, 2014 04:29 PM
Borav
Jun 20, 2012 12:53 PM
FitPilot
Aug 4, 2009 02:08 PM
yasirfaheem
Aug 4, 2008 10:39 PM
