What exactly are the rules of a break in period
Old Nov 13, 2007 | 09:01 PM
pastafarian's Avatar
What exactly are the rules/limits of the break in of the honda fit? Like is there a certain rpm you can't go over or something? Please help and be as detailed as possible.
Old Nov 13, 2007 | 09:07 PM
TOOL's Avatar
Do a little bit of searching and you will find a ton of info on this topic..
But really just dont abuse the car, drive regular dont go racing or redline your car and it will be just fine!
Old Nov 13, 2007 | 09:35 PM
doctordoom's Avatar
Supervillain
refer to your owner's manual for the generally accepted method of engine break-in. i think it's just don't gun the motor, drive smoothly, don't go over 3500 rpm? i'm not sure. just drive like you're taking your driver's license test and you'll be alright.
Old Nov 13, 2007 | 09:37 PM
azlynn's Avatar
The owner's manual really does not say much of anything - one or two tiny lines and that's it. Everyone here keeps saying to read it, but it doesn't say much.
Old Nov 13, 2007 | 10:00 PM
What happens if you go over it like mad and gun it like crazy? J/w
Old Nov 13, 2007 | 11:41 PM
claymore's Avatar
There is a big LONNNGGG post on this subject SEARCH FOR IT!!!
Old Nov 13, 2007 | 11:54 PM
Firebat666's Avatar
just dont drive like a manic all the time.... i drove it a little hard a few times but mostly just avg. my dealer said " they build these things so well now, just don't drive from NYC to Boston on cruise control... vary the RPMs a little"
Old Nov 14, 2007 | 12:17 AM
Lyshk0's Avatar
what i've always done, is keep it under 4.5k, and make sure you load the engine at various rpms. that is to say, put it under load, stress it a bit. this will help the piston rings seal well against the walls. really though; the engines are already in good shape outta the factory, what you need to do is vary the rpms and the load, so that the ecu can learn the best way to run the car. after 600 miles, you should be ok to do whatever.
also don't change the oil till 5k (or the light comes on). this nearly killed me, cause i try not to go that long, especially on original oil; but is is important for the block to absorb some of the additives to keep it in good shape for the long run. i read this in another thread on here somewhere.
Old Nov 14, 2007 | 11:29 AM
manxman's Avatar
Make up your own "rules". Everybody else does. In the previously mentioned old threads, you'll find every possible opinion. Any driving habits that would cause drive train harm and cost Honda money in warranty repairs would be clearly warned about in your owner's manual.
Old Nov 14, 2007 | 11:48 AM
osborne's Avatar
The only rule you need to know about the break in period is DO NOT BREAK YOUR CAR. Derr.
Old Nov 14, 2007 | 12:59 PM
Steeldog's Avatar
Also, don't break into anyone else's car.
Take it easy for the first couple tankfuls. Don't get the oil changed until your maintenance minder says it's getting close to time. That's all.
Don't do anything stoopit, and Honda does the rest for you.
fastredshoes
Mar 27, 2013 12:05 AM
fitfreak89
Jun 20, 2011 03:50 AM
Fitcious
Jul 15, 2009 02:16 AM
Tif
Aug 21, 2008 11:25 PM
Apex77
Oct 1, 2007 06:39 PM
