Comparing 2 Headers Design
Old Nov 21, 2007 | 03:05 PM
prossett's Avatar
Not interested in the company names (you'll recognize them anyways! ) - just would appreciate your comments on the different designs of these two headers:
Headers A
Headers B
Old Nov 21, 2007 | 06:48 PM
tricolor's Avatar
Hum... Header A looks like a 4-2-1 design. From other members comments, it means increase of torque at low and mid RPM. Header B is a common 4-1 design, wich yield its added torque at mid and high RPM.
Personnally, I wish Header A had been available when I was looking for one. Who wants to trade?
Old Nov 21, 2007 | 08:24 PM
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
Header A: WeaponR
Header B: MeganR
Id suggest header A. Smooth and they arent known for leaking.
Old Nov 28, 2007 | 12:00 PM
Wave's Avatar
I vote Header J's
Old Nov 28, 2007 | 12:12 PM
Injundon's Avatar
Normally this would be the case, but for the Honda fit and most newer cars with the exhaust manifold on the firewall side. the piping run can't be made long enough to pulse tune a 4-2-1 design. The length and diameter of the pipe cause a certin resonance depending on their respective length and diameter. if the pipes are too short, the engine would have to rev rediculously high for scavenging effect to occur. WeaponR made a product hoping people don't know this and are selling snake oil.
For the fit especially since the "header" bolts right to the catalytic converter there's no way you ca make the piping long enough for low end torque jump. With the Fit what will make power is exhaust gas velocity, which depends on bends, piping size and mostly just a good smooth flowing collector so there's as little turbulance as possible.
Old Nov 28, 2007 | 06:07 PM
tricolor's Avatar
Will you be the mechanic to install my yet to purchase SuperCharge?
[quote=Injundon;199674]Normally this would be the case, but for the Honda fit and most newer cars with the exhaust manifold on the firewall side. the piping run can't be made long enough to pulse tune a 4-2-1 design.
Thanks for the input... you reconciliate me with my Megan 4-1, although I might have to remove it if I go for the Jachson's Supercharge!!! What is holding me back, for one thing, is that I don't know a competent mechanic (in MTL) for that type of modification. Do you?
Old Nov 28, 2007 | 08:17 PM
LDO's Avatar
LDO
not to hi-jack but how do these compare to the DC Sports Header?
Old Nov 28, 2007 | 09:40 PM
Injundon's Avatar
[quote=tricolor;199791]
I know several competant mechanics in montreal . Installing headers or a Supercharger kit is actually pretty easy for anyone who is mechanically inclined. PM me if you need a list of places that are good/trustworthy
Old Nov 29, 2007 | 03:25 AM
vbo's Avatar
vbo
Header A is better, but you think you can see the difference ??? I think no.
Buy the less cost.
Old Nov 29, 2007 | 03:54 AM
koolkevin1107's Avatar
oh btw u don't need 2 remove ur headers to install the jackson racing supercharger b/c it's a rotorex design (it mounts to a belt, not to the exhaust manifold like a turbocharger) so u can keep ur headers on.
Old Nov 29, 2007 | 05:04 AM
prossett's Avatar
Old Nov 29, 2007 | 07:10 AM
tricolor's Avatar
That's great news. My vote goes for the Megan, simply because I paid 230$ delivered and it still does the job after one full year.
Old Nov 29, 2007 | 09:12 AM
claymore's Avatar
You better look and see if those are the same as your car. As far as I know they are USA ONLY headers. In other parts of the world the collector area is different and the non-USDM ones have longer pipes not the shorties like the USDM one.
This is a non-USDM header. Note there is NO 0-2 sensor in the header ours goes into the front of the converter. So look under you car and check before you order yours.
Old Nov 29, 2007 | 09:15 AM
LDO's Avatar
LDO
Originally Posted by prossett
Prossett,
What was the pic suppose to tell me? I know the finish is different, I meant how does it compare to the other two in performance. Sorry, I should have been clearer on that.
siccmonkey
21
Feb 29, 2012 01:28 AM
Blue-Civic-Hybrid
Nov 27, 2010 08:26 PM
Staff@WR
103
Sep 17, 2008 04:54 AM
