ABS Warning light
Old Jun 3, 2005 | 01:06 AM
MattA
Guest
Posts: n/a
ABS Warning light
Hi All,
I am cross posting this here since Honda Passport and Isuzu Rodeo are
prety much identical. I have a 2000 Rodeo LS 4X4. Recently my ABS
warning light (Orange) coming on and couldn't reset it. Not sure which
wheel sonsor is the culprit. Local Isuzu dealer would charge $85 to
identify where the problem is. Unfortunately, the warranty period is
over and I don't feel like spending $85 + the repair cost. If I can get
some help from you guys to identify the problem, I may be able to get
OEM parts or from the junkyards.
Local AutoZone has OBD readers but not for ABS Warnings. Any help is
appreciated.
Thanks in advance.
Mathew
SoCalMike
Guest
Posts: n/a
Re: ABS Warning light
MattA wrote:
> Hi All,
how do you know its a sensor, as opposed to the pump or whatever? just
curious.
> appreciated.
a helm manual might help locate/troubleshoot the problem. id be tempted
to take em all out one at a time and clean/examine em, if possible. i
dont know if a voltmeter would help give a reading, or not.
> Thanks in advance.
> Mathew
Professor
Guest
Posts: n/a
You need to find out which code(s) are stored before you do anything.
Professor
www.telstar-electronics.com
MattA wrote:
> Hi All,
> appreciated.
> Thanks in advance.
> Mathew
motsco_ _
Guest
Posts: n/a
MattA wrote:
> Hi All,
> appreciated.
> Thanks in advance.
> Mathew
First, determine if it happens only if the vehicle is moving. If it can
sit on the driveway and idle for five minutes and not generate a light,
it's probably a wheel sensor. Once you start moving, the system looks
for a clean signal from all four sensors (as well as the speed sensor).
Inspect the tone rings on the front for obvious rust / dirty grease
accumulation. Knowing your mileage is a help too. Have the brakes been
bled according to the schedule?
'Curly'
MattA
Guest
Posts: n/a
Thanks for the info. My vehicle has 65K on it. The ABS warning light is
stale all the time. The moment you start the vehicle it comes on and I
don't
have to drive. For the last two weeks it was on and off ocationaly.
Now, it
will not go away. I can rule out the rear since the rear brakes were
changed
2 month ago and I did not get any warning at that time. My suspecion is
the
front. I bought this vehicle as used and not know all the history. The
braking part is working find just the warning light is concerning me. I
can
ask my mechanic to bleed and see whether it solve the problem. I have
the
Haynes manual but there is nothing about ABS sensor or speed sensor. I
don't
even know how it would looks like.
Is there any web link I can check for additional info?
Appreciate your help.
Mathew
Seth
Guest
Posts: n/a
"MattA" <matta@ipass.net> wrote in message
news:1117582109.590977.322110@g47g2000cwa.googlegr oups.com...
> don't
> Now, it
> changed
> the
> can
> the
> don't
If the ABS light is going on before you roll, then it is most likely NOT a
wheel sensor. They haven't been exercised at that point, so can't show
fault.
Pump or ECU would be my suspicion.
chip
Guest
Posts: n/a
On Wed, 01 Jun 2005 00:13:48 GMT, "Seth"
>news:1117582109.590977.322110@g47g2000cwa.googleg roups.com...
>> don't
>> Now, it
>> changed
>> the
>> can
>> the
>> don't
>fault.
follow the wires from the rear sensors, they will end up on the
drivers side near the rear of the fuel tank at a 2 pin connector. i've
seen a lot of them where the wires are broken right there.
best i can do with out a code.
Chip
Santiad
Mar 27, 2013 10:44 AM
Santiad
Oct 17, 2011 02:55 PM
RandomKoko
Jan 30, 2009 05:18 PM
RandomKoko
Jan 27, 2009 10:49 PM
Mike
May 4, 2005 11:16 AM
