HID's cause poor radio reception....
Old Jan 10, 2008 | 06:58 PM
deocder's Avatar
Turn on the HID's and the radio reception goes to crap.....turn them off, no problem...
Anyone else experience this?
Old Jan 10, 2008 | 07:02 PM
JDMchris.com's Avatar
I run THIS
mine is fine.
Old Jan 10, 2008 | 07:08 PM
yeamans17's Avatar
its probably because the way the oem bulbs are grounded, and since you're using the oem ground it causing your issue. if you don't have a retrofit you should swap back to your stock bulbs because your blinding everyone
Old Jan 10, 2008 | 08:28 PM
Injundon's Avatar
Your getting some electrical bleed from the ballasts to the cars chassis. What HID kit do you have?. Was it a direct "plug in" it or did you have to do some splicng? if it was a plug-in kit were the connectors are all sealed or do they leave some of the prongs exposed.
Old Jan 10, 2008 | 09:11 PM
deocder's Avatar
Thanks for the replies!
Just for clarification, this is a retro and I made a new harness to take power straight from the battery.
The kit is made by Xenith Xenons....
The interface between the stock system and my harness is at the H4 socket. Since our lights are ground switched, I'm using the following schematic:
Old Jan 10, 2008 | 09:25 PM
yeamans17's Avatar
you might want to try grounding to the body instead of the battery maybe? the way honda headlights are wired has always confused me
Old Jan 10, 2008 | 09:34 PM
deocder's Avatar
Hmm. It is directly grounded to the body but at the same point that the battery connects to the chassis.
Old Jan 10, 2008 | 10:21 PM
Injundon's Avatar
Are the ballasts built in the retrofit housing or seperate..if they are seperate, are they mounted directly to the body of the car? They should be mounted to metal and the case of the ballas should be grounded to the body. if it isn't. Ground the ballasts to the cars body or back to the battery... if it is grounded. Then you have a bleed off situation and one of yo ballasts is gonzo.
Old Jan 10, 2008 | 10:31 PM
Zangoose GD3 Blue's Avatar
yeah i got that problem with the Brand i have... to eliminate that problem either i dont listen to the radio or put in my I-pod
Old Jan 10, 2008 | 11:33 PM
azncarbos's Avatar
i have installed a lot xenith xenons kits on fits, none never had that problem, did recently brought the kit from xenith xenons, if so you have 1 ground cable right???, if so move the that ground to the 14mm bolt right next to the battery (look at the picture blow) but if you have the older kit you have 3 ground cable, then put one ground on the 10mm bolt that hold the headlight on the side on each headlight and the last one on near the srs. that should solve it.
the 14mm bolt
the 10mm bolt
Old Jan 11, 2008 | 12:48 AM
deocder's Avatar
I moved it to the 10 mm bolt under the headlights as shown in your picture. This had no effect on the problem. I removed both ballasts and checked their chassis grounds and found them to be fine as well. I disconnected the passenger side ballast and the reception improved, yet there was still noticeable interference.
I sent a message to George over at Xenith Xenons and his reply was:
"This happens when your ballast is installed too close to the radio
receptor. A simple change in the area of ballast mounting will fix the
problem
" -George Wu
But I have mounted the ballasts where everyone else is mounting theirs. I wonder if I got some bad ballasts....
Or is there some fault in my wiring? Tomorrow I will bypass the harness and plug directly into the stock H4 socket to see if there is any improvement.
Old Jan 11, 2008 | 01:43 AM
SD_MR_FIT's Avatar
i have had my hid's for 9k miles and they have not caused any problems.
maybe i guess it is the ground, but i dont know if i grounded them that well or not, cant remember.
Old Jan 11, 2008 | 08:56 AM
deocder's Avatar
You mention "1 ground cable" and I'm not sure if I have that or not. The connection to the ballast consists of a two conductor cable that I have conected to left/right ballast +/- as shown in the schematic above. There are no separate grounds beyond that.
Old Jan 11, 2008 | 03:56 PM
azncarbos's Avatar
is the cable cover by a plastic or fabric materials, if the plastic materials then you have one ground cable, but if you the fabric materials then you have 2 to 3 ground cable.
Do have the bi xenon or the halogen hi and hid low??????
Old Jan 11, 2008 | 06:50 PM
deocder's Avatar
Yea, it's the plastic material, there are two wires, black and white. Since its a retrofit, I am using a D2S bulb. My projectors are bi xenon.
Old Jan 15, 2008 | 01:30 AM
azncarbos's Avatar
the black, power the bulb and the white, allow the bi xenon function to happen. i think???? correct if im wrong.... I looking at it,it just maybe the connection and ground issue to cause bad reception, our fit already have some bad radio reception, if you follow my DIY on installing you shouldnt have any problem....
Old Jan 15, 2008 | 08:36 AM
deocder's Avatar
Actually, the black and white wires that go to the ballast, I thought, were positive and negative.....the bi-xenon functionality is separate from this. At least in my case since the projectors have solenoids that control the high beam.
CBerg20
Jun 4, 2015 11:52 AM
bmwbob
Jan 26, 2013 11:54 PM
Remedi
Dec 10, 2012 01:37 PM
get_FIT
14
Nov 4, 2010 09:43 PM
noshatch
Sep 2, 2010 11:30 PM
