Sponsored by:
Sponsored by: CARiD
i hear the ocean in my dash board...
Old Jan 22, 2008 | 07:51 PM
sosoqtpinoy's Avatar
everytime i start my car i always hear this liquidy, watery noise in the dash... can some one explain what that noise is? it eventually stops after a while... but i just wanna know if its a problem that id have to fix? THANKS!!!
Old Jan 22, 2008 | 07:56 PM
JDMchris.com's Avatar
I run THIS
this has been covdered many many many many many many many many many many times.
its the gas being sucked to the motor
Old Jan 24, 2008 | 07:29 PM
TurnOnTrance's Avatar
remember your sitting over you gas tank. next time you get in to your car before you start it shut the door and sway left and right and you should hear the same sound
Old Jan 27, 2008 | 08:17 PM
SHG_Mike's Avatar
could also be coolant moving from the motor to the heater core. I here this sound on my EK hatch on occasion
Old Feb 29, 2008 | 07:16 AM
jdjohnson9's Avatar
I had the same thing. When you installed your intake did you lose a lot of coolant? That happened to me and i couldnt figure it out until i checked my coolant level. That was my problem otherwise its the fuel tank. Hope that helps.
Old Feb 29, 2008 | 08:09 AM
NIGHTHAWKSI's Avatar
i lost coolant when isntalling an intake and heard this noise. i thought it was an air pocket in the heater core...ended up just being low on coolant. fill up your cooalnt reserve and you should be fine.
gfrobe
Feb 10, 2015 07:21 PM
Chairman Kaga
Jan 1, 2011 09:56 PM
Fitguy07
Nov 8, 2009 07:15 PM
aredrumc
Jul 10, 2009 08:38 PM
bodeen
Nov 13, 2008 09:30 AM
