RetroFit - a few pics
Old Jan 29, 2008 | 01:52 AM
deocder's Avatar
Here are a couple pics of my retrofit. I followed smeister's DIY,
https://www.fitfreak.net/forums/fit-...rojectors.html
Thank you very much!
A couple of modifications changed the orientation of the projector mounting screws....I made it so that the projectors could be adjusted from the front instead of having to pull out the reflector.
For the projector, I used FX35 Bi-xenon's color shifted with TSX clear lenses.
Despite the over-exposed night shot, the line is horizontal with color shifts around the cutoff's. There is a crisp line of pure white (6000 K) at the cutoff's followed by a sliver of blue on top of that, and a deep purple on top of that. I need to get some better shots of that.
I am very pleased with the outcome....except that the color shift seems too strong at times.
Old Jan 29, 2008 | 02:11 AM
smeister's Avatar
Wow! That looks great. Glad my DIY has helped ONE person.
BTW, on my retro I don't take out the reflector neither.
Old Jan 29, 2008 | 02:25 AM
deocder's Avatar
Thanks!
Can you explain how you make the adjustments in terms of left to right? How do you access the nuts to tighten them?
Old Jan 29, 2008 | 07:10 AM
japspeed's Avatar
very cool, where in soflo are you at, i would like to do the retro fit also, maybe you could show me, also where did you find the parts and how much, and would you want to do mine if i paid you. one more question i just a ordered bixenon hid kit, can i use this with the retro or do i have to use factory hid bulbs and ballasts
Old Jan 29, 2008 | 09:38 AM
deocder's Avatar
Thanks!
I'm everywhere from Delray Beach to Hollywood along 95... I've been tempted to drive up to Orlando for the meets up there....I'm not sure how well Fit's are represented down here in SOFL....
I bought the FX35's from smeister...he had an extra set. I got the TSX lenses from e-bay....I got an extra set of headlights to put in the car while I was working on the retro. All that cost about $350....
I received an H4 Bi-xenon kit from George at Xenith Xenons.....then I decided to go with the retofit and he let me exchange that kit with the D2S kit. The D2S is the only bulb that will plug into factory projectors. The kits cost $140...
And if you want to equate time with money....it took me about 2 weeks to finish them, working a few days for a few hours at a time...
I would like to do another set, however I was only able to do mine between semesters at school....since I'm back in school, I have very little time.....but smeister will do them for a good price, and he may even have parts on hand... https://www.fitfreak.net/forums/members/smeister.html
Old Jan 29, 2008 | 09:42 AM
smeister's Avatar
There are three screws that you can adjust. There is a nut, lock washer, and flat washer on each side of the reflector bowl on the screw. So you can push the projector out on any of the three screws to adjust the cutoff.
My first retrofit took me months to finish, so you did pretty well in 2 weeks.
Also, if you want to buy a custom retrofit from me you don't HAVE to provide the parts if I have them in stock. I am working on getting more parts so there is no hassle shipping parts to me and I can just have them ready made to sell PLUG AND PLAY.
Old Jan 29, 2008 | 10:07 AM
deocder's Avatar
Does that mean that you drilled out the threads in the projector housing? Thats what I did....then I secured the projector bowl the same way you did...I also jbwelded a lock nut to the back of the reflector....that way I have a tight joint that can still be rotated. It sounds like we did the same thing, I just misunderstood somewhere along the line.....
Old Jan 29, 2008 | 11:13 AM
smeister's Avatar
I didnt drill out the holes in the projector. I went to Ace Hardware and got the same threaded screws that were 2" long. I didn't use any JBWeld. The lock washers do the job nicely especially since it is already tightened from both sides with the reflector in the middle.
To adjust, I just untightened the nuts and moved the reflector out a little on that screw and retightened on the spot I wanted, I did that to all three screws on both projectors until the cutoff was aligned. I hope that clears the cutoff adjustment.
You could JBWeld everything once you are confident its perfect and stays perfect. I think that's what you did.
Old Jan 29, 2008 | 12:48 PM
fits_all's Avatar
nice job. i want to see a daylight pic from far away if u can.
still pending on this..will let u know smeister. i liked that plug&play notice u gave heh
Old Jan 29, 2008 | 12:51 PM
fitjunkie's Avatar
oooh...I'm drooling over that thing...did you guys use the stock weather molding in the back? otherwise the moisture may condense into the headlights...
Old Jan 29, 2008 | 05:15 PM
deocder's Avatar
Yes, I used the stock rubber seal but had to cut it a bit to accommodate the bulb socket...
I'll get some pictures from a distance as soon as I can....
smeister, I looked at your DIY again...Does the projector rest against the reflector at all?
This shows how I did the mounting/adjustment screws:
Here is a picture of the screw through the housing. I drilled out the threads to provide free movement. I added a nylon spacer to lift the washers away from the bowl, otherwise the screw would be forced to one side. Then a flat, split, flat and a nut. This allows for the screw to rotate freely while preventing the bowl separating from the lens housing.
On the back of the reflector I put lock nuts that have a nylon insert that provides enough friction to only allow for small movements at a time of the screw and at the same time keeps it in position.
These were JB welded into place...
All I had to do was rotate the screws from the front of the lens to adjust left/right and up/down.
Old Jan 29, 2008 | 11:01 PM
smeister's Avatar
I see...that's why you drilled it out. Yeah I actually move both of the nuts (front and back) everytime I need to move the projector for adjustments. Cool idea though...I am sure it makes the adjustments easier, but then you have to JBWeld the nuts on the back.
How much of a pain was it to take off the reflector bowl? lol I give you props on just doing that.
Old Jan 30, 2008 | 01:30 PM
FELIXY69's Avatar
SICK i Love it...
do u have pic of the whole car with it on ?
Old Jan 30, 2008 | 04:05 PM
deocder's Avatar
Stand-by for pics...... she needs a bath before I even think about pulling out the camera!
Old Jan 30, 2008 | 04:49 PM
Fitftw's Avatar
looks nice man!
Old Feb 9, 2008 | 04:59 PM
fitjunkie's Avatar
Hey deocder, can you post a pic of the weather strip that you used for your project?? What kind of weather strip are they...I'm thinking of doing the same but not sure if the weather strip is strong enought to hold the bowl in place...
Old Feb 10, 2008 | 06:07 AM
greekdaddy000's Avatar
GOOD JOB! When will you begin offering your services?
Old Feb 11, 2008 | 12:06 AM
deocder's Avatar
Originally Posted by fitjunkie
Hey deocder, can you post a pic of the weather strip that you used for your project?? What kind of weather strip are they...I'm thinking of doing the same but not sure if the weather strip is strong enough to hold the bowl in place...
I did not use weatherstrip to hold the bowl to the reflector, I used JB Weld in for points around the base of the lens holder.....
Thanks! I simply do not have the time to produce these ..... you'll have to go to smeister...he's them man for all your retro needs!
Old Feb 11, 2008 | 12:09 AM
deocder's Avatar
Here's a few more pics:
Old Feb 13, 2008 | 02:02 PM
fitjunkie's Avatar
Interesting...how does the JB weld look after you mount it? Meaning the part between the lens and the bowl, how did you seal up that gap w/o weatherstrip? Can you post a picture of a close up shot of the lens the bowl? Smeister used weatherstrip, but I'm still not sure what to use yet as I'm not sure if it's strong enough over the long run with constant road abuse...
If_It_Fits
Dec 18, 2018 01:31 PM
smeister
135
Nov 16, 2012 05:55 PM
BlueBoogers
Aug 1, 2012 08:12 AM
smeister
105
Jul 28, 2008 03:39 AM
rcantu
47
Jul 12, 2007 09:05 PM
