I Am Freaking Rubbing!
Old Feb 9, 2008 | 09:06 PM
andyd's Avatar
Okay....
I just put on some Rota Slipstreams 16X7 with a 40 offest. The tire is 205/45/16 and i am rubbing on the drivers rear fender when someone is sitting in the back. Pretty badly. I was told by many that they have their car lowered and only occasionally rub with the same setup I have... Any ideas?
Old Feb 9, 2008 | 09:27 PM
FELIXY69's Avatar
roll ur fenders
or run 195/45/16 i think 205 is too big
Old Feb 9, 2008 | 09:30 PM
solbrothers's Avatar
what are you lowered on?
Old Feb 9, 2008 | 09:32 PM
andyd's Avatar
I am not lowerd...
Old Feb 9, 2008 | 09:35 PM
WOW! that's scary! im lowered on skunk2's and just ordered wheels. 16x7 +38 offset. with 205/45/16 tires. now you're scaring me hahaha
Old Feb 9, 2008 | 09:45 PM
also depends on the tire. some summer tires have bold shoulders
and are wider than tires of the same width.
Old Feb 9, 2008 | 09:50 PM
Fit of RAGE's Avatar
actually, i'm rolling on 16x7 205/45r16 Work Emotion Kai CR's and i'm rubbing too. I'm also riding stock height.
Old Feb 9, 2008 | 09:53 PM
andyd's Avatar
Got any ideas to fix it?
Old Feb 9, 2008 | 10:03 PM
lidoshorty02's Avatar
wow i hav 17s lowered and it was so low i had 2 put spring spacers
Old Feb 10, 2008 | 04:00 AM
going to try spacers first. then maybe roll the fenders alittle
Old Feb 10, 2008 | 04:32 AM
billykim's Avatar
i say definently use smaller tires. i use 195/45/16. if you are even planning on a drop, this is a MUST. I run that tire size with a Tanabe DF210 springs and only rub on hard corners.
Old Feb 10, 2008 | 07:16 AM
japspeed's Avatar
dude, your going to rub, im rubbing on df210 with 195/55/15, on 38 offset 15x7, i think i have to go to a 195/50 maybe, anybody got any thought on this.
Old Feb 10, 2008 | 09:15 AM
question is WHERE is it rubbing inside the fender.
then you know wat you need to do next.
Old Feb 10, 2008 | 10:09 AM
DynamicFit's Avatar
Spacers are going to make you rub even harder.
Old Feb 10, 2008 | 10:12 AM
smeister's Avatar
I had Slips in 16X7 with 45 series tires and you will rub with passengers/weight in the rear even if you roll your fenders.
Old Feb 10, 2008 | 12:17 PM
andyd's Avatar
Your making me sad
Old Feb 10, 2008 | 12:39 PM
yeah *cries*
Old Feb 10, 2008 | 12:47 PM
smeister's Avatar
You can prove me wrong...but when I had that setup with weight in the rear...it would rub. The fender will rub/cut into the tire a little with all that weight in the rear. It's just has no where else to go unless you have more cmaber.
TOOL's Avatar
Im not a expert but im pretty sure you will rub with that setup..
Tyler
Old Feb 10, 2008 | 12:49 PM
orly? link to a camber kit plz? i don't mind running camber, as long as it'll save my tires lol
