I Am Freaking Rubbing!
Old Feb 25, 2008 | 02:12 AM
  #41
SD_MR_FIT's Avatar
man i dont get it. im SLAMMED. tire tucking all 4 tires. running 17x7.5 rims with 45 offset.
i barely rubb in the back when people are sitting. i only rub when people are in my car and i hit MAD dips.
but usually i dont rub if its just me and my girl. i take that back, i DONT rub at all with just me and here in my car.
Old Feb 25, 2008 | 08:42 PM
  #42
holloway2006's Avatar
Could everyone that rubs/doesn't rub post what kind of tire they're using? Seems like as several have said that the tire size is the main issue. That would help a bunch!
Old Feb 26, 2008 | 12:24 PM
  #43
eldaino's Avatar
yeah, you need to post your tires man!
205/45/r16's should not rub, even with your offset.
slips were on my short list for rims but i may have to eliminate them.
on jlbmotorsports, its lists the slips with a quite a few different offsets, some as big as +45 which is pretty close to the stock specs. any reason why you didn't opt for these?
Old Feb 26, 2008 | 01:34 PM
  #44
smatts's Avatar
Honda Fit Forums Moderator
Guys I'm on HFP rims (16x6.5 +55 offset) w/ 205/45/16 Tires and I don't rub and I've had 5 people in the car. Lowered on T1R S-Coils too. The Tires are Kuhmo Ecsta ASX.
Old Feb 26, 2008 | 03:09 PM
  #45
eldaino's Avatar
i think this is the big deal. the HFP rims (which i would get in a heartbeat if it wasn't for the weight and possible mpg drop) are the proper offset.
Maybe if he had the +42 or +45 offset version he would be fine? but from what jim has commented on the 'rubbing...what works" thread, his tire size and rim offset without lowering shouldn't rub.
Old Mar 12, 2008 | 04:56 PM
  #46
tattoopunk031's Avatar
My rims are 15x6.5 40+ offset with 205/50-15 tires. I rubbed in the front and rear. I rolled the fenders in the rear and i still have slight rubbing issues. Im also lowered on eibach sportline springs so im sure that doesnt help. Im thinkin of just switchin the tires to 195/50-15 and i think everything should be fixed. But who knows. I was thinkin about just dealing with the rubbing til i get coilovers sometime and maybe that would fix it if i raise it up a little bit.
Old Mar 13, 2008 | 07:17 AM
  #47
MarkyMark's Avatar
there is a sticky that lists wheels, offsets, and tires and whether it rubs or not....
Cornerstrike
Oct 2, 2011 06:05 AM
thebluepotato
29
May 3, 2010 11:14 AM
Contrabida Face
Mar 12, 2009 12:25 AM
ds62987
Dec 15, 2008 09:36 PM
WhaTisJDM?
Nov 29, 2007 09:29 PM
