does the fit idle higher when cold?
Old Feb 19, 2008 | 09:32 PM
pastafarian's Avatar
Its been rather cold where I live ~30 degrees F for a few days, and I have noticed that when I start my fit, which sits in a garage that is prob ~34 degrees, it idles at 1500rpm! Once my car has warmed up a fair amount, it idles at like 800rpm. Am I crazy? Why does it idle so high when cold? IS there anything I can do to get the rpm's down when idling?
Old Feb 19, 2008 | 09:36 PM
SPON FIT's Avatar
its warming up
Fray Adjacent's Avatar
Senior Member
Yes. It will idle faster when cold.
Idling faster helps pump the oil better when it's cold. Oil circulation is critical.
Old Feb 19, 2008 | 09:42 PM
well since its idle higher that means its using more fuel correct?
Is there a way to make it warm up faster or start it warmer?
Old Feb 19, 2008 | 09:43 PM
doctordoom's Avatar
Supervillain
yup what he said. and driving it cold and getting the rpm even higher, but gently, will help circulate the oil even more.
Old Feb 19, 2008 | 09:45 PM
TOOL's Avatar
Of course it idles higher whn its warming up! Just like any engine on anything lol!
Tyler
Old Feb 19, 2008 | 10:32 PM
idle up is normal on all cars.
Old Feb 20, 2008 | 01:49 AM
Snap Fit's Avatar
its essentially the choke...better than having to do it yourself (trust us on that one...for the peeps with older cars )
you can make it warm up much faster if you drive it gently right away (its ok to do it and probably better for the car too, more circulation, as was said before) or haul a$$ right away ...it will heat up really quicky ...but...not so good with regards to wear and tear
Old Feb 20, 2008 | 01:52 AM
m-man@sbcglobal.net's Avatar
what its also doing is intentially running the engine lean, which helps light off the cat faster, as well as moving more oil, it needs a higher idle to stay stable, and another reason it it programmed high is to warm the engine up as fast as possible for,..again emmisions reasons.
Old Feb 20, 2008 | 03:47 AM
Snap Fit's Avatar
nice addition
Old Feb 22, 2008 | 03:49 AM
storm88000's Avatar
Frequent FitFreak Poster
Old Feb 22, 2008 | 10:16 AM
willmax11's Avatar
You should be in Cold Country to see how the "Hot Idle" works. LOL
With -30C it takes a long time to go off fast idle. I let it sit because putting an AT in reverse, cold trans. and fast idle may cause stress
on the tran. parts.
When my GFI kept tripping off 2 days ago I had to forego my usual 1 hr.
for the block heater. Took a long time for the idle to come down to 1,000
RPM. All my older carb. cars you could kick down the idle sooner
but don't know if it works the same on the Fit.
Old Feb 22, 2008 | 10:23 AM
Tofuman's Avatar
Honda engine block heater.
$48 at handaaccessories.com
korgster
Jan 31, 2020 11:13 AM
phenoyz
Feb 26, 2016 02:42 AM
chilis trip
Dec 17, 2015 12:31 PM
hqly
Sep 4, 2006 03:20 AM
bibby
Apr 27, 2006 05:23 PM
