Honda dealer alarm problem. I need help.
Old Feb 21, 2008 | 06:34 PM
cph81's Avatar
My car alarm is going off like crazy. It went off by itself. Nothing was touch, hit or shake. After I used the remote to unlock and lock, alarm will go off ~30sec after the "beep". So I have to turn it off, manually under the driver seat. I went back to the dealer. They said it is too sensitive. Got it adjust. Few hours later, same thing happen. Today, back to dealer. The tech checked and found the "pin 5" was set "on". He said if pin 5 is on. Alarm will go off randomly. So he turned it off and told me it will be fine now. 3 hours later.
Same thing happen again!! The alarm went off for no reason. After it went off once, it will keep going off. No matter how many time I unlock/lock the door with remote. It will go off ~30 sec after the "beep". I don't know anything about car alarm. Do you guys think the sensor is bad? Computer bad? Or installation problem. I noticed it's acting crazy when the car is cold. Everything worked fine after I drive and got the car warm.
The car and alarm are new. Add-on from the dealer. They installed before I pick up the car.
Thanks.
Old Feb 21, 2008 | 06:44 PM
Firebat666's Avatar
wow... um thas messed up... keep on the dealer to fix it??? obv. something wrong on their end...
Old Feb 21, 2008 | 06:56 PM
FITrunner's Avatar
Sounds like a bad cpu on the alarm. Have the dealer fix/replace it. I used to have an alarm like that years back on my nsx usually went off randomly because the ECU was so sensitive that changes in temperature made it go off, then for fun you wouldn't be able to shut it off! Damn thing.
Old Feb 21, 2008 | 07:15 PM
cph81's Avatar
I'll tell them replace the cpu. Thanks for the info.
Hope it'll fix it. Thanks.
Old Feb 21, 2008 | 07:41 PM
Kelmar's Avatar
Frequent FitFreak Poster
Is this an aftermarket alarm or the one for the base model?
Old Feb 21, 2008 | 07:48 PM
cph81's Avatar
I don't know what brand but it's install by the dealer. I has the sport model so I don't know what they install on the base model.
OliviaNewtonJohn
Sep 8, 2011 04:02 PM
Blackbeard
Nov 8, 2010 11:52 AM
bobmorning
Apr 12, 2009 08:33 PM
terrykim321
Jun 8, 2008 07:53 PM
toypup
Sep 21, 2005 08:31 PM
