honda motor oil
honda motor oil
Hi
In the car manual Honda go on about using only 'Honda motor oil' in your car.
Now when I spoke to a few honda dealers about this they dont seem to know about 'any honda motor oil'
So does it exist or just a myth???
Hope this helps.
tonyd3773 (Video Guru)
You can buy Honda labeled motor oil by the quart at the dealer over here. Obviously it is just re-packaged oil from one of the big companies. IIRC, it tests/tested almost identical to Exxon SuperFlo.
When you get it changed at the dealer, you're going to get whatever brand the dealership get the best deal on in bulk purchasing at that time.
Makes no difference as long as it's the correct spec/weight.
Im not having much luck with 'Honda motor oil' over here in the UK
If its just a myth then why do they Honda keep mentioning it in their manual?
Why not just say use whatevers available so long as its the right spec/grade etc
I have owned several different makes of cars and have always been able to get the makers brand of oil no problem
Cant believe you cant for a honda!
If its just a myth then why do they ‘Honda’ keep mentioning it in their manual?
SevereService
Dec 4, 2011 06:18 PM
Buzzbomb
Feb 19, 2010 02:55 PM
mtunofun
Oct 27, 2009 01:07 AM
Daņiel
Oct 16, 2009 03:08 PM
