honda motor oil
Old Feb 25, 2008 | 05:02 PM
joe bloggs's Avatar
honda motor oil
Hi
In the car manual Honda go on about using only 'Honda motor oil' in your car.
Now when I spoke to a few honda dealers about this they dont seem to know about 'any honda motor oil'
So does it exist or just a myth???
Old Feb 25, 2008 | 05:22 PM
doctordoom's Avatar
Supervillain
If i remember correctly, our manuals in the US say to use honda motor oil or any other SAE certified oil of the right grade (5w20).
Old Feb 25, 2008 | 06:11 PM
tonyd3773's Avatar
Smile
Agree totally with the above statement.....if you bring your FIT to the dealer when it's time to change your oil....you will not have any issues!!
Hope this helps.
tonyd3773 (Video Guru)
Old Feb 25, 2008 | 10:07 PM
MPG-Motoring's Avatar
Eneos 5W-30 FTW!
Old Feb 25, 2008 | 10:57 PM
halestorm0's Avatar
You can buy Honda labeled motor oil by the quart at the dealer over here. Obviously it is just re-packaged oil from one of the big companies. IIRC, it tests/tested almost identical to Exxon SuperFlo.
When you get it changed at the dealer, you're going to get whatever brand the dealership get the best deal on in bulk purchasing at that time.
Makes no difference as long as it's the correct spec/weight.
Old Feb 28, 2008 | 04:36 PM
joe bloggs's Avatar
Im not having much luck with 'Honda motor oil' over here in the UK
If its just a myth then why do they ‘Honda’ keep mentioning it in their manual?
Why not just say use whatevers available so long as its the right spec/grade etc
I have owned several different makes of cars and have always been able to get the makers brand of oil no problem
Cant believe you cant for a honda!
Old Feb 28, 2008 | 04:44 PM
doctordoom's Avatar
Supervillain
Are you sure it's saying that about the motor oil? In our US manuals it says to only use Honda's products for the transmission fluid, but for motor oil it says to use any certified brand of the right specifications. I wonder why it would be different for you in the UK.
Old Feb 28, 2008 | 04:57 PM
joe bloggs's Avatar
I quote from the UK manual:
' It is highly recommended that you use genuine Honda Motor Oil in your vehicle for as long as you own it '
Old Feb 28, 2008 | 05:15 PM
doctordoom's Avatar
Supervillain
I see. In that case, I'm as bewildered as you are.
Old Feb 28, 2008 | 05:50 PM
fit4jenn's Avatar
you should be able to buy honda oil from the dealer. if not then you can use mobil oil because thats who makes the oil for honda anyway
Old Feb 28, 2008 | 06:36 PM
halestorm0's Avatar
Marketing baby, marketing. Honda just wants their taste after you've left the lot. Pay it no mind.
dcoaster
Jul 18, 2015 10:47 PM
SevereService
Dec 4, 2011 06:18 PM
Buzzbomb
Feb 19, 2010 02:55 PM
mtunofun
Oct 27, 2009 01:07 AM
Daņiel
Oct 16, 2009 03:08 PM
