Ideal Tire Pressure on Stock Sport Fit?
Old Feb 28, 2008 | 12:13 PM
SickFit's Avatar
My little light (low air on tires) turned on today as I was coming to work. I checked to make sure I didnt have a flatand thankfully I dont. I do not have my manual on hand so this is why i'm asking if anyone knows the ideal tire pressure for me to have on my tires when I go to put air in them.
Old Feb 28, 2008 | 12:52 PM
s0x's Avatar
s0x
open your drivers side door there is a sticker that tells you what the tire preasure should be on the door jam
Old Feb 28, 2008 | 01:07 PM
Cat's Avatar
Cat
32 - I have to check my tires every month because they seem to loose a little -probably the crazy weather we have here in WV
Cat :x
Old Feb 28, 2008 | 01:08 PM
SickFit's Avatar
Your the man! I will check it out when I get to my car this afternoon.
Old Feb 28, 2008 | 01:09 PM
SickFit's Avatar
Dude can you believe its like 58 degrees outside here in Miami. Its beautiful.
Maybe that initial drop in weather changed the tire pressure dramatically and activated it. But I will definately make sure everything is to right pressure. Thanks guys.
Old Feb 28, 2008 | 03:36 PM
joe bloggs's Avatar
yeh thats right the pressures on a sticker on the drivers door pillar
Old Jun 12, 2008 | 11:39 AM
tbird911's Avatar
My tires say 44psi max-- the tires were inflated to 32 from the dealer-- what's right?
Old Jun 12, 2008 | 11:47 AM
Sid 6.7's Avatar
Why so serious?
There are tons of threads here about what is the ideal tire pressure. Do a lot of research here with the search function before you make a decision.
Your driving style, your climate, and a lot of other things come into play when determining what is your ideal inflation pressure.
For spirited driving/good handling and eco minded individuals, a higher pressure is used. For comfort, a lower pressure is used.
Here is one of the latest threads concerning tire inflation pressure. Notice that my first sentence identifies this topic as hotly debated. That statement was proven true with the very next post.
https://www.fitfreak.net/forums/fit-...-pressure.html
Old Jun 12, 2008 | 11:54 AM
tbird911's Avatar
Thanks for thw quick reply . . .
Old Jun 12, 2008 | 03:37 PM
joe bloggs's Avatar
If you look inside on the drivers door pillar, the bit where the door latches onto theres a sticker which shows the correct pressures
FIT410S
Aug 22, 2015 11:57 PM
japspeed
Apr 11, 2014 09:29 AM
agios11
Aug 24, 2012 11:41 PM
hollins2007
Dec 11, 2008 09:34 PM
boots11234
Oct 27, 2008 03:55 PM
