2004 Accord airbag/seatbelt issue
Old Jul 3, 2005 | 11:47 AM
kathy2004
Guest
Posts: n/a
I was in a bery minor fender bump. Now the SRS light stays on and the sealt
belt is "locked" in an out position and will not retract. Any thoughts?
TomP
Guest
Posts: n/a
Re: 2004 Accord airbag/seatbelt issue
Yea, your bump deployed the seat belt tensioner. That means the SRS control
unit, the front impact sensors and the seat belt MUST be replaced.
Tp,
-------- __o
----- -\<. -------- __o
No Lawsuit Ever Fixed A Moron...
Old Jul 5, 2005 | 03:31 PM
Deni
Guest
Posts: n/a
Isn't that great news?
Kind of a stupid system... if the airbags don't pop... the system should not
semi-deploy!
"TomP" <roadcyc@socal.rr.com> wrote in message
news:42C7F409.94277A96@socal.rr.com...
>> sealt
> control
> Tp,
> -------- __o
Old Jul 5, 2005 | 04:42 PM
dold@XReXX2004X.usenet.us.com
Guest
Posts: n/a
> not semi-deploy!
Why deploy $4000 worth of airbags when a simple explosive tensioner is
sufficient? The explosive seat belt system on newer cars even relaxes
after deployment, to allow a decelleration of the upper torso, rather than
an abrupt stop that used to break a lot of collarbones. In my 2005, not
all of the airbags will deploy when one deploys, and they can deploy with
differring rates. The 2003 is dual stage, dual threshold, but both fronts
deploy at the same time. The side air bags are independent of the front.
The owners' guide explains all of this, including the note that the SRS
light indicates a fault in any portion of the system.
Clarence A Dold - Hidden Valley (Lake County) CA USA 38.8,-122.5
fit7ad
Aug 26, 2013 05:51 AM
phogroian
Jun 6, 2010 09:30 PM
Matt
May 4, 2005 04:44 PM
techman41973@yahoo.com
May 4, 2005 11:16 AM
PK
