humming noise or grinding noise
Old Jul 3, 2005 | 07:34 PM
rynniki
Guest
Posts: n/a
I just noticed a humming or grinding noise when i drive, i have civic dx
manual tranny,127,000 miles,just had new boots and axles on,wheel bearing
and hub put on. so what could it be????i was thinking an alignment or
wheel balancing....
Old Jul 4, 2005 | 01:45 PM
jjjsan
Guest
Posts: n/a
Re: humming noise or grinding noise
Might be water pump problem, when was timing belt, water pump replaced?
Does the noise change with engine rpm or with wheel speed?
Old Jul 4, 2005 | 04:30 PM
rynniki
Guest
Posts: n/a
the timing belt was changed around 90,000 by the previous owner i dont know
about the water pump, there is no kind of fluids under the car except for
the a/c water..the noise gets louder the faster i go. it just started all
of a sudden
Old Jul 5, 2005 | 04:42 PM
jjjsan
Guest
Posts: n/a
do you hear the noise when car is in park and engine running?
Old Jul 6, 2005 | 07:40 AM
rynniki
Guest
Posts: n/a
no i just got it checked and its the wheel bearings i just had done 4
months ago so they are replacing it
flyingby
Mar 5, 2025 10:45 PM
geepondy2
Nov 26, 2012 05:54 PM
atauer
Feb 5, 2010 05:21 PM
dgff
Jun 12, 2008 09:43 PM
Kevin
Jul 15, 2005 10:47 AM
