Who's running aftermarket B pipe with stock muffler?
Old Mar 16, 2008 | 12:25 PM
davela72's Avatar
I really can't say that any of the axle back exhaust's thrill me, look wise. I wouldn't mind a little tone to the exhaust so I was thinking about replacing the stock B pipe with an aftermarket one. Are there certain ones that won't bolt up to the factory muffler and ones that will?
I did some searching but didn't really find too much on this...
Thanks!
Old Mar 16, 2008 | 08:48 PM
Arisenfury's Avatar
I don't think you'll get much noise by just changing out the b-pipes, the only one I can think of off the top of my head that doesn't have a resonator built in is the J's Racing and that's like $800.
If you just want noise while keeping the stock muffler have a shop put a straight pipe where your resonator was, can't guaruntee it'll sound great though.
Old Mar 16, 2008 | 09:19 PM
davela72's Avatar
Yeah, after thinking about this I think my best bet is to just get an axle back and be done.
Old Mar 17, 2008 | 01:53 AM
SD_MR_FIT's Avatar
uh,well like the other guy said, build a straight pipe through the resonator. or what you can do is get someone to weld you up a 4x9 magnaflow muffler. and just call it a day,since your maintaining your stock b pipe then it should still be somewhat quiet.
it will look like stock too, because it really small and if they weld a tip that bends down, you will be set. since i guess you like the look of your stock muffler.
or just buy a header. for 200 bucks, i can almost guaranteed that your exhaust will sound a bit throatier . at least all the people i know who have put the header on with stock catback sounds meaner. who knows....
or just have someone weld you up a 24 inch glasspack and have no axle back. i was thinking about doing this, where your b pipe is straight, just have a glasspack right there, and have no tip or anything. that will definitely sound BEEFY, dont know how it would be performance wise...
freestyle
Mar 12, 2020 02:06 PM
Kipperskipper
Jul 28, 2017 11:35 PM
kevinkidstar138
May 27, 2009 12:26 AM
HEMI-Fit
Apr 28, 2008 11:52 PM
K20A3Fit
Feb 19, 2008 02:52 PM
