how to install factory front bumper licecnse plate holder?
Old Mar 17, 2008 | 10:00 AM
ghostagent's Avatar
i got a bag full of crap that looks like the front license plate mount. The bag was opened so i don't have instructions as to where and how to install this. does any one have instructions or suggestions they can give me for a proper install? hopefully no screws through the front bumper?? or maybe a PDF guide?
thanks
Old Mar 17, 2008 | 10:35 AM
yeamans17's Avatar
They don't come with instructions, but here you go, in the back there should be 2 metal clips, look under the big main part of the front bumper, in the center area of the open spot, you should see 2 areas to slide the clips up onto, then you hold the bracket up to them and tighten down the 10mm bolts into the clips to hold the bracket into place.
Old Mar 17, 2008 | 10:48 AM
ghostagent's Avatar
no screws on clips for the top of the plate?
Old Mar 17, 2008 | 10:56 AM
yeamans17's Avatar
The top of the plate is held in place at the top, but theres no holes in the bumper on top, There may be a location for you to screw one in if you wish, but I never installed those when I was at the dealership. I didn't want to put a hole into the bumper
Old Mar 17, 2008 | 12:54 PM
Mr.Ball's Avatar
There's a old post of for this with picture's in the search section.
Old Mar 17, 2008 | 01:48 PM
ghostagent's Avatar
i've actually searched but wasn't able to find anything aside from the side mount license plate.
anyhow, i went to check the car. i will just use the 2 screws on the holding plate under the main bumper. I've added some duck tape to the edges of the plate holder itself so the top part wouldn't rub the paint off the bumper.
Vince_TB
Aug 15, 2011 07:48 PM
bwv1060b
Oct 20, 2008 01:26 PM
HaulSmall
Mar 2, 2008 09:46 PM
jono21
Apr 1, 2007 08:00 AM
DrDiff
Mar 22, 2007 12:04 PM
