Audio system question..
Old Mar 22, 2008 | 07:27 PM
JPfit's Avatar
Question Audio system question..
I presently have a pretty nice sound system in my car that I'd like to trade in that I would like to use just the subwoofer from..
I have this MTX 10" subwoofer which features a built in amp. that I had installed by a friend (who is no where to be found).. and I'd like to install that subwoofer in the 2009 Fit, and be able to hook it up to the Fit's stereo. Is that possible..? (I have a custom mounted volume control built into my lower dash, which I figure that might have to be done too)..
Anyone..?
JP
Old Mar 22, 2008 | 07:49 PM
cavie187's Avatar
Anyone..?
JP
Yes it is possible.
I am not familiar with the factory unit on the fit, but i would venture to guess that it does NOT have built in sub/av out jacks. If this is the case (which is very likely), you will have to get a modulator (also called an RF switch or RF crossover depending on where you go) and splice into your rear speakers for a signal. In addition to that you will have to wire in a remote wire to any power source that is accessible when the vehicle is in the accessory/on position. Then you can route a power cable (with in line fuse) to your battery (positive) terminal, and find a chassis ground for your ground wire to the amp.
hope this helps.
Old Mar 22, 2008 | 08:19 PM
Arisenfury's Avatar
Hard to say on the 2009 since we don't have it. But the 2008s would need a line out converter, or if your amp has a high-level input you could use that as well.
Old Mar 22, 2008 | 08:29 PM
cavie187's Avatar
I think the sub/amp combo the OP is talking about is most likely a truck style box with a very simplistic amplifier input. Usually only 1 set of rca ports and a small dial for tuning and Db level. Sometimes a switch for lpf/No lpf.
Old Mar 22, 2008 | 08:49 PM
Arisenfury's Avatar
Then he'll need the line-out converter unless the 2009s have RCA preouts, which I doubt.
ToddF
31
May 17, 2024 09:52 PM
shamoo
Jun 8, 2012 10:53 PM
Vash
May 8, 2010 11:56 PM
bovineblitz
Mar 9, 2010 11:19 AM
DJYT
Nov 20, 2007 11:25 AM
