Rotas & Tires
Old Mar 23, 2008 | 02:11 AM
base model 5MT's Avatar
Rotas & Tires
So, I have some Rota Slips 15X6.5's, 40 offset on stock suspension and I'm deciding on what size tire I should get to avoid having any rubbing issues. I am deciding between 195/55-15's and 205/50-15. What do y'all think? Thanks.
Old Mar 23, 2008 | 05:53 PM
MNfit's Avatar
I would think 195/55/15 would be fine, thats whats on the car stock
Old Mar 25, 2008 | 07:20 PM
I ended up ordering the 205/50-15's. Hopefully there are no rubbing issues!
Old Mar 29, 2008 | 02:04 PM
MINI-Fit's Avatar
Stock rim is 15x6" with +55 offset.
15x6.5" is only slightly wider, +40 offset brings the wheel much farther to the outside of the car so tire diameter needs to be close to or no larger than stock for best clearance.
185/60-15 23.6" tire diameter Load rating 84
195/55-15 23.3" tire diameter Load rating 84
205/50-15 23.1" tire diameter Load rating 86
Alternatively you can also choose tires that are a little less than stock tire diameter but watch the load ratings.
195/50-15 22.8" tire diameter Load rating 82
205/50-15 should work just fine. Note that wider tires will improve handling and grip but in snow they don't cut through as easily.
I have run Kosei K1 TS 15x7 rims et+37 and Bridgestone RE-01R in 195/50-15 on my Fit Sport with stock suspension and it did fine with no rubbing. I have also run Sport Edition 15x6 rims +50 et and 205/50-15 tires with no problems.
mismith356
May 4, 2017 11:23 PM
KennyisFez
Jun 23, 2015 11:10 PM
Remedi
Jan 6, 2011 06:33 PM
FITGD3
Jan 21, 2008 07:00 AM
