Looking for All Season Tires
Old Mar 27, 2008 | 12:56 AM
Cooper's Fit's Avatar
I have 45,000 miles on my 2007 Honda Fit Sport A/T and about 6mm of treadwear left. I drive my Fit as my commuter car about 110 miles per day. So far, I've been happy with the OEM Dunlops. From what I've read, a lot of people complained about the noise, but I can't complain as my previous vehicles have been SUVs. As I live in the Chicago area, I need All Season tires and I have never used Winter tires and have no plan to either. Surprisingly, over the last 2 winters, the Fit on the OEMs handled well in the snow.
Has anyone driven with Fuzion VRi?
Old Mar 27, 2008 | 01:01 AM
SD_MR_FIT's Avatar
no dont get fusion tires i hate them.
from their all season to the performance. big thumbs down for them.
Old Mar 27, 2008 | 01:06 AM
SD_MR_FIT's Avatar
since you uh drive that much arnt you more concerned about the mileage for the tire. i know costco tire center sells tires that are warrantied up to 85k miles. i mean they are michellins so they cant be that bad. uh,
for all season i think the goodyear rsa tires are good. i dont really run much all seasons. but i know that hankook has really good performance tires, i wouldnt doubt that their all season line would be great aswell.
Old Mar 27, 2008 | 01:11 AM
As long as I can get 50,000 miles on the tires I'm fine with replacing the tires every 2 years. I'm not sold that the 85k mile tires actually will last that long.
Old Mar 27, 2008 | 06:22 PM
SD_MR_FIT's Avatar
no they wont, but they are warrantied for that long. so if they dont last, bring em back to costco heh
Old Mar 29, 2008 | 07:21 AM
MINI-Fit's Avatar
I haven't driven the VRi but reviews are OK
Fuzion VRi
For Ultra HP All Season tires-
Edge Racing - Item Details
Falken Ze-912 $65 each and 360 treadwear. Should work.
195/55-15.
Kumho Ecsta ASX $69 each 420 treadwear
BF Goodrich g-Force Super Sport A/S- in 205/50-15 $86 each 400 treadwear
Or
High Perf All Season tires-
Consumer Survey Results By Category
Michelin Pilot Exalto A/S $126 each 400 treadwear
BF Goodrich Traction T/A V $87 each 440 treadwear
Fuzion VRi $65 each 400 treadwear
Or
Grand Touring All Season tires-
Goodyear Eagle ResponsEdge $99 each 440 treadwear
Anything about 400 treadwear should work 50,000 miles. Just keep them at correct tire pressure.
Narrower tires will work better in snow but I did list one that was 205/50-15.
The more expensive tires above do a little better in snow and offer better handling than the less expensive tires.
The Grand Touring AS tire offers more comfort and longer treadwear.
Old Mar 29, 2008 | 07:57 AM
^^ he's our tire guru.
one thing to note about the Ziex912's. they are decent tires with
lots of tread wear. they dont grip well in sub-freezing temps.
they do however work pretty well in 40F+ temps.
Old Mar 29, 2008 | 01:38 PM
MINI-Fit's Avatar
Hey Kenchan,
You live in Chicago like the OP, what would be your suggested tire of choice given the weather?
I lived in Chicago for 5 years and three winters had temperatures down to minus degrees and -80 with windchill. I ran stock Honda All Season tires (Dunlop) on my civic sedan and generic elcheapo All season tires on my Chevy Chevette. Naturally I didn't drive very fast when it got too cold and I was always careful. I'm sure the rubber was not gripping at all with the low temperatures. Actually most everything wasn't working too good at -80. I had to park outdoors.
If you look at some of the ratings from tirerack you will see that not all of the mentioned tires perform as well in the snow. If you want traction for winter pick something with decently high scores from owners-
next level would be-
Kumho ecsta ASX
By comparison you can see how well the Stock Dunlop SP31 A/S was rated by customers at tirerack:
Dunlop SP31 A/S
Looking at Passenger All Season tires for 195/55-15 only the Dunlop SP31 is found. If you change to 195/60-15 which is a little taller than stock at 24.2" you find the very highly rated and tested:
Goodyear Assurance TripleTred $92 each 740 treadwear
Good ratings for wet or dry handling, winter weather, good comfort and long treadwear.
Old Mar 29, 2008 | 06:31 PM
MINI-Fit you know me from the 'other' forum. i recommend
the AvidH4's and also the Sumitomo HTR+'s if they are offered in our
size.
i haven't tried much of the newer a/s tires...the latest being Ziex912
which grips like crap in sub-freezing temps.
Old Mar 29, 2008 | 07:17 PM
MINI-Fit's Avatar
size.
OK, I thought that since you have the Falken Ze-912s now you might like them better but I guess not. Seems like if under 40 degrees is not agreeable with the 912's it's not really well suited beyond areas that have very mild winters.
Yokohama Avid H4s (High Performance All Season tire) 500 treadwear
Yokohama AVID H4S
Testing Value-Oriented High Performance All-Season Tires 2006
185/65-14 $64 each
195/60-15 $67 each, Taller than stock 24.3" tire diameter
205/45-16 $77 each
205/40-17 $79 each
Sumitomo HTR+ (Ultra High Perf All Season tire) 400 treadwear
Testing Ultra High Performance All-Season Tires Without Ultra High Prices
195/55-15 $58 each
205/40-16 $51 each, 22.4" tire diameter
215/40-16 $56 each, 22.8" tire diameter, fits rims 7-8.5" wide
205/40-17 $60 each, 80 load rating
Old Apr 1, 2008 | 12:37 AM
Well guys, I'm still looking for the perfect All Season tires. I'm still leaning towards the Fusion VRi. From all the reviews, it seems like the best bang for the buck. I figure that no matter what tire I end up buying, they will only last me 2 years or 50,000 miles whether their warranties are 40,000 or 50,000+. Worse case scenario is if they do not perform well in the winter, then I can just buy winter tires if need be. I'm not planning on spending more than $450 to have these or any tires put on as I'm also in the market for new tires on my 2006 BMW Z4. The Bridgestone OEM Run Flat Tires on that are just horrible, so with the new tires, I'm looking to getting 18" or 19" rims. I'll definitely be purchasing the rims and tires from tirerack as they can mount and balance them and all I'll have to do is jack the car up, take off the old and put on the new. By the time it's all said and done, I'll be dishing out about $2,000 for both cars this spring/summer.
Old Apr 2, 2008 | 03:31 PM
for your Z4, i recommend the BS RE050 PolePositions. i run that on my
G35C... 245/35/19 and 275/35/19. very nice tires.
Old Apr 3, 2008 | 12:27 PM
eldaino's Avatar
go with the yoko's that have have been reccomended, those tires are fantastic in the winter and they grip pretty good in the summer. plus, they should meet or exceed your mileage requirement.
Old Apr 3, 2008 | 09:49 PM
yokohama's meaning, AvidH4's. avids + awd on my legacy = super
traction.
SilverEX15
Jan 18, 2016 03:48 PM
bluesboy
Dec 31, 2011 07:40 PM
xonexlifex
Nov 10, 2009 12:28 AM
FitSam
Dec 9, 2008 02:49 PM
Sera
Dec 2, 2007 04:46 PM
