Can clutch be changed from above or below?
Old Jul 19, 2005 | 01:35 PM
Rocky
Guest
Posts: n/a
94 civic 1.5L lx 5 speed - when I change the clutch - do I need a hoist to
remove tranny from above or a floor jack type cradle to remove tranny from
below - doing the job this weekend in my driveway.
special tools - just an alignement dowel tool?
Old Jul 19, 2005 | 03:34 PM
T L via CarKB.com
Guest
Posts: n/a
Re: Can clutch be changed from above or below?
When we did my 87 prelude, we used a hoist to raise the trannie and get it
clear, but then it has to come out the bottom. i lowered it onto my buddy's
chest, and he rolled out with it on the creeper. its only about 120lbs or so,
its manageable.
if you plan to take off the flywheel to machine (highly recommended), make
sure to have a set of 16 point sockets handy. Regular 6 sided sockets will
strip those bolts.
Don't forget to replace your release bearing, as well as the pilot bearing if
your car has one (the prelude did not have a pilot bearing, just a tapered
output shaft on the engine)
Terry in Winnipeg
Message posted via CarKB.com
http://www.carkb.com/Uwe/Forums.aspx...-cars/200507/1
Old Jul 19, 2005 | 11:26 PM
T L via CarKB.com
Guest
Posts: n/a
oops i meant 12 point sockets....
>its manageable.
>strip those bolts.
>Terry in Winnipeg
Old Jul 20, 2005 | 03:32 PM
MAT
Guest
Posts: n/a
"T L via CarKB.com" <forum@CarKB.com> wrote in message
news:51943AE3A04F5@CarKB.com...
I was always under the impression that six sided sockets were better for
high torque/stripping prone applications?
Old Jul 20, 2005 | 06:23 PM
disallow via CarKB.com
Guest
Posts: n/a
But these bolts are actually 12 sided.... Put a 6 sided socket on them and
they would round out pretty quick....
Message posted via http://www.carkb.com
Old Jul 20, 2005 | 08:34 PM
MAT
Guest
Posts: n/a
"disallow via CarKB.com" <forum@CarKB.com> wrote in message
news:519F1FE085857@CarKB.com...
> and
OIC, thanks!
Old Jul 20, 2005 | 10:31 PM
SoCalMike
Guest
Posts: n/a
they the ones that look like a 12-pointed star?
Old Jul 21, 2005 | 09:37 AM
Guest
Posts: n/a
We did it without air, but it was a bitch. If you have access to impact and
air, I would go for that.
Rocky wrote:
>are the bolts hard to break free or would I need air tools?
>my local parts store said they could resurface the flyweek in 45 min for I
>think $45 us but I might have my 45s mixed up.
>[quoted text clipped - 20 lines]
Old Jul 21, 2005 | 11:36 AM
T L via CarKB.com
Guest
Posts: n/a
Yup. They were like that on the 87 'lude, as well as my 98 civic.
Old Jul 21, 2005 | 09:39 PM
chip
Guest
Posts: n/a
On Thu, 21 Jul 2005 12:24:57 GMT, "disallow via CarKB.com"
honda says never resurface their flywheels. they are somewhat
flexible and should not be ground. just hit the glaze with sand
paper.. pull the tranny out the bottom, the almost fall out of a 94
civic. less than 2 hours to change.
Chip
Pumpkin
Nov 4, 2017 08:21 AM
TroyGgd3
Oct 26, 2016 08:30 AM
s0x
Nov 14, 2014 06:47 PM
Red Diablo
Aug 17, 2009 10:40 PM
Lynn
Aug 6, 2005 09:33 AM
