What's faster-Fit, older Accords?
Old Apr 17, 2008 | 02:39 PM
piperpiperpiper's Avatar
I'm curious. I have two friends with accords. One is a 2000 Accord coupe V6, the other is a 2001 Accord four door with the mid-range 4 cyl. Going off of 0-60 times, the Fit MT runs around 8.7-10 secs? How does this compare to those older Accords? All I can find online are for other years/engines.
-joshua
Old Apr 17, 2008 | 02:41 PM
TOOL's Avatar
Im sure the V6 coupe would own the Fit.
The 4cyl sedan may be rather close. Its a good question.
Tyler
Old Apr 17, 2008 | 02:42 PM
The closest I can find is a time of 7.9 seconds for the 2000 V6 coupe's 0-60. Does that sound right?
-piper
Old Apr 17, 2008 | 02:44 PM
Nerdsrock22's Avatar
Well I think you can bet you'll get smoked by the v6, and in a straight line, I'd doubt you be able to touch the four either with its 2.3.
Fits ain't fast...
edit* but then again the 2.3 is only 135hp. I think Tool is right, it would be a close fight.
Old Apr 17, 2008 | 02:46 PM
Originally Posted by Nerdsrock22
Fits ain't fast...
Ha, don't I know it...
Old Apr 17, 2008 | 02:51 PM
Fit:2471lb
Accord: 3990lb
Fit 22.67 hp/lb
Accord: 29.56hp/lb
Old Apr 17, 2008 | 02:58 PM
eldaino's Avatar
the j series engine in the 2000 v-6 accords is actually the same that was used in the 03-07 versions....those made more power due to some ecu retuning and revised intake manifolds...i think the net power gain was some 40hp! Obviously a stock fit doesnt' stand a chance against that, but against a 200hp 2000 accord, i still think that the fit would loose the upper hand, and you'd have to REALLy flog it to keep up.
even the f23 came in a 150hp version, and that alone may be enough to trounce the fit. the 135hp version may not get away so easily. and most f23's that you'll encounter would be the 150hp version, as only the dx got the 130 hp verison, and i can't even remember the last time i saw a 97-02 dx accord.
Tofuman's Avatar
do they have manual transmissions? the V6 will probably smoke a fit. the 4 cylinder will be close. especially if it has an automatic.
0-60 times are not as important as 1/4 mi. times in terms of racing.
you'd have a better chance on a race track than a drag strip.
Old Apr 17, 2008 | 02:59 PM
Fit:2471lb
Accord: 3990lb
Fit 22.67 hp/lb
Accord: 29.56hp/lb
I hate to be "that guy", but isn't it lb/hp?
Old Apr 17, 2008 | 03:00 PM
these vehicles are both automatics. Why you would buy a new car with an auto is beyond me...
*wink
Old Apr 17, 2008 | 03:02 PM
And the V6 would have 14.74 lbs/hp. Yeah, a flogging.
-piper
Old Apr 17, 2008 | 03:03 PM
The fit would have to weigh 1606.66 lbs to pace the V6 accord. Know how I can lose 864 lbs?
ha! This is fun!
-piper
Old Apr 17, 2008 | 03:12 PM
corey415's Avatar
Fit:2471lb
Accord: 3990lb
Fit 22.67 hp/lb
Accord: 29.56hp/lb
The heaviest 2008 Accord weighs 3567 lbs.
I dont think the 3990 lb figure is correct.
Old Apr 17, 2008 | 03:13 PM
We're talking about a 2000 V6 Accord auto coupe and a 2001 Accord sedan with the 135hp 4 cyl.
-joshua
Old Apr 17, 2008 | 03:14 PM
i got that off wiki...could be wrong.
well, probably wrong knowing wiki.
and yeah your right about lb/hp, i knew that didnt look right. trying to write fast at work....
Old Apr 17, 2008 | 03:17 PM
eat less and exercise?
Old Apr 17, 2008 | 03:19 PM
GAFIT's Avatar
I'd put my money on a manual Fit over any automatic 4 cylinder Accord and over almost any automatic N/A 4 cylinder. Low torque and auto's are a bad match. The QR25 and old KA24's in Nissan's are an exception because they're fairly torquey. I'm sure there are other exceptions also. The v6 would destroy the Fit though.
Old Apr 17, 2008 | 03:24 PM
I'm sure the situation will come up where he'll challenge me (we engage in little competitions all the time), and I just don't want to come up too short!
Old Apr 17, 2008 | 03:27 PM
coupdetat's Avatar
Where the heck did you get 3900lbs for an Accord from? That's WAY off. That's more like the weight of a Hemi 300C.... not an older I4 Accord
Old Apr 17, 2008 | 03:29 PM
yeamans17's Avatar
My 92 accord had an f22a1, h23 intake manifold, cold air intake, megan header, and greddy sp2 exhaust with the stock trans only put down a 16.4 in the quarter, I swapped that for the m2b4 h22 lsd trans but never made it to the track, but it made a hell of a difference, but without it the Fit feels quicker
