Interior Cleaning
Old Apr 25, 2008 | 08:52 PM
Ciggy's Avatar
Interior Cleaning
I decided my car was dirty and to do the windows, clean the dash, the doors, and vacuum. After doing everything all nice and off to my hockey game a friend and I realize that the dash looks like crap the doors to. I used Armor All wipes to do the whole thing and their are swirls of the stuff and goopy areas. The directions are wipe down area and let dry I had the windows open it should have been dry but instead two days later I'm stuck with swirls all over the car. What do you use to keep the dash and plastics nice and shiny. Please help. Thanks.
Old Apr 26, 2008 | 01:49 AM
Sam Misled's Avatar
I used them as well and the same thing happened to me. BUT I just re-used them over and over and did an even application to the entire dash/doors and they worked great.
Old Apr 26, 2008 | 02:48 AM
Illusive's Avatar
I try to refrain from using those plastic enhancers. Over time, they will dry out and crack your dash if you don't apply it regularly. With our weather here, it's just not in the cards. And also, there is an application problem. You really need to saturate it to get it into all those nooks and crannies, otherwise it'll look weird and blotchy.
Old Apr 26, 2008 | 05:05 AM
Rob22315's Avatar
A lot of folks use an all-purpose cleaner (APC) diluted 10 or 20 to 1 for vinyl cleaning. Woolite diluted 4 or 5 to 1 makes a very gentle interior cleaner too.
You might have to go stronger to get all the AA goop off though. Try wiping the excess off with an MF cloth first and see if you can live with that.
Old Apr 26, 2008 | 08:30 AM
Ciggy's Avatar
Thanks guys after work ill attempt to get this crap off of my dash.
Old Apr 26, 2008 | 05:11 PM
davela72's Avatar
Ditto on the Woolite! As far as a protectant goes, try to find some 1Z Cockpit Premium. It has a very matte finish, not shiny, and protects as well.
Old Apr 26, 2008 | 05:24 PM
airborne200208's Avatar
I just use a damp wash cloth. I have no problems with swirls or 'goop.' For glass I use distilled water and newspaper, leaves no streaks and I don't have to wipe up any over spray from the plastic pieces.
Old Apr 26, 2008 | 11:59 PM
saiko's Avatar
Avid FitFreak Poster
I used those too. the first time i used them, i had the same problem, but now it doesn't happen anymore. hahaha it's weird...
Old Apr 27, 2008 | 11:09 AM
for the Fit's dash and door panels use Prima Nero. I use it dilluted 50/50
with distilled water, but straight Nero is fine. you DONOT want to use
armorall. it is garbage.
if the car is really dirty use Nero straight.
If not Prima Nero, Aero303 is your best bet. you can get these from
Detailer'sParadise.
these will leave behind a nice matte finish. none of that glossy crap.
Detailers Paradise: Premium Car Care Products, Auto Detailing
Old Apr 27, 2008 | 11:12 AM
For cleaning the interior, i have yet to find any product better
than Griot's InteriorCleaner. It works very well and is virtually scentless.
they also now have CarpetCleaner as well.
you can get them here:
Car Care, Detail Supplies, Garage Organization, Car Accessories - Griot's Garage 800-345-5789
Old Apr 27, 2008 | 05:30 PM
wpgfit's Avatar
how do you clean the interior carpet without fluffing it up? (cargo area behind seats etc).
it seems like really cheap carpet that wears easily (the hole on the edge of my floormat on the drivers side attests to this)
Old Apr 27, 2008 | 07:29 PM
i used my shopvac to clean it as much as it could, then sprayed the
InteriorCleaner directly over the soiled area. then took a cotton towel
and worked the product in and wiped clean. might get those Griot's
MF shop towels while you're at it. they didn't have those back when
i ordered the interior cleaner.
as you said, dont use a hard bristled brush cause it does pull up
the flooring weaves and turns into a nasty blob of tangled up nylon.
Old Apr 29, 2008 | 12:55 PM
hondaf1racing's Avatar
I clean the dash and trim using simple green (diluted to 1:10) and shine it up with Vinylex. You can pick up both at any auto store. Seats and Carpet I just use my craftsman shop vac and its brush attachment.
Old Apr 29, 2008 | 03:32 PM
yeamans17's Avatar
Your best bet for cleaning the dash or any other interior plastic pieces is the pick up a can of Honda Polish. You can buy it online at Bernardi Honda. I bought a can there after I bought my Fit, just make sure you keep it warm and don't let it freeze sitting in your garage. I doubted the functionality of it until I used it, now I use it on everything.
Old Apr 29, 2008 | 06:18 PM
los_creeper's Avatar
just as illusive mentioned once you use those "protectants" you HAVE to keep using them other wise your dash WILL start to crack, but you'll be ok as long as you keep up with it. i use to use stuff like that in my 91 crx (avatar) and it looked great... i just didn't like the greasy feel and how it collected dust and dirt.
now in my fit, i vaccuum first, blow out with air compressor, and then if it needs it (which isn't a lot), just do a quick wipe with one of the damp micro fiber rags i used to dry the car. pristine everytime, like the day i drove it off the lot.
if you're a smoker, or you got kids, or pets go with SIMPLE GREEN. i was a detailer for a couple body shops in vegas and that stuff cleans everything.
Old Apr 29, 2008 | 08:30 PM
Fit317's Avatar
Lightbulb
Originally Posted by bryanback
I also used those armor all cleaning wipes and hated them. I'm not sure what I can use the remaining half of a tube on, but it sure won't be my car. I also got a tube of the protectant wipes, which left things really greasy and a little gross, until I sort of hand-buffed it with a microfiber cloth, which made it look real good.
But, it seems like most people tend to just use water and a microfiber towel. I haven't tried that yet, but it seems harmless enough that if it doesn't clean the way you want, it at least won't hurt anything.
Yea dude i agree, armor all sucks. its sooooo greasy looking. If you want teh best look, youll be surprised but glass cleaner works AMAZINGLY!!!! no streaks, greasyness, or anyhting. Try just regular glass cleaner. just spray ur entire dash, plastic and whatever with it. and then wipe off with a regular towel. try it and get back at me how u liked it.
Old Apr 29, 2008 | 10:28 PM
that's if you use garbage dressing. won't crack if you use Prima Nero
or Aero303. there's a reason why detailers spend the extra money.
for the product's finish, efficiency, durability, flexibility.
Old Apr 30, 2008 | 12:20 PM
TOOL's Avatar
I never have and never will use Armor all on any kind on interior part of any of my cars. To be honest i dont like a shiny plastic interior, it came as a flat plastic and i want it to stay that way. And as Illusive said, it does screw up yout interior over time.
Tyler
Old Apr 30, 2008 | 12:39 PM
i dont use that crap on the exterior either...
for exterior black plastic nothing beats this. and this is after
experimenting with many different kinda trim dressing.
just released last year.
SCD Black Wow the only exterior trim dressing you will ever need!
Old Apr 30, 2008 | 01:48 PM
jezzy's jazz's Avatar
i use some megs quick interior cleaner and a micro fibre cloth, does the job for me...
kitkit201
May 5, 2014 06:14 PM
sLiVeRwOrM
Oct 30, 2012 10:40 PM
BlueRaspberryFit
Aug 27, 2012 02:16 PM
ats34
May 6, 2009 09:52 PM
geepondy
Aug 25, 2008 05:57 PM
