tires are wobbely
Old May 14, 2008 | 10:58 AM
mikow's Avatar
tires are wobbely
so i just recently purchased a set of wheels and the tires when i roll it on the ground it wobbles... this is bad and i feel lumps on the tires btw.
so question,
if i like buy new tires,
do i just go to a tire shop and give them the rims and wobbly tires with the new tires i bought and their going to assemble it for me?
Old May 14, 2008 | 11:13 AM
DVFlyer's Avatar
A tire shop will be able to solve any problems you have with the wheels or tires.... or both.
Old May 14, 2008 | 04:23 PM
mahout's Avatar
Yes very bad. VERY DANGEROUS. Suspect hub bore too small, wheels hanging up on hub, lug nuts not tightened, or wheel or wheels bent. Possibly tire)s) out of round but that would cause lumpy ride rather than wobbly.
DO NOT DRIVE UNTIL PROBLEM CORRECTED. PERIOD.
PS for those unaware, if the hub bore does not seat on the hub face squarely, the wheel inner bore will jam on the hub center and the wheel 'slants' on the hub when the lugnuts are tightened. When you take the lugnuts off you can usually see if all lugs are not equally through the lug bolt holes. Even if they look even, if the wheel cannot be easily removed, the wheel is stuck on the hub, that is virtually a guarantee the hub bore is too small.
Grinder
Grind/file the opening to clear the hub center but max 1/16" More than that wheel isn't intended to work.
If the wheel doesn't fit easily, stop and check offsets, caliper clearances, and hub bore.
Good luck.
Old May 14, 2008 | 07:42 PM
mikow's Avatar
Grinder
Good luck.
Oh dam
Thanks man for the well written reply
Fiy they are hx rims
The tires are alright but, 2 of them just doesn’t sit straight.
planning to put the crooked ones in the back and the good tires in the front
then carry 2 spares in the back(my stocks)
just in case the tires blow.
And.. yeah I think I need to get spacers too cause of the caliper
K
Thanks dude
Old May 14, 2008 | 07:50 PM
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
Replace all the tires. I wouldnt roll on them at all.
Old May 14, 2008 | 09:49 PM
kancerr's Avatar
yeah dont risk damaging your rims...just replace the tires. ;/
Old May 14, 2008 | 10:37 PM
Fitcapo's Avatar
Almost sounds like wheels weren't balanced or tires not mounted properly....
I would have them remount the tires check the balance and take it for a small test drive after that if it is still riding funny then I would replace the tires for sure. Go back to were you got the stuff from and make them fix it.
Ohh not on car yet so don't put them on car then lol.... didn't read whole first post....
Old May 14, 2008 | 10:42 PM
solbrothers's Avatar
you talking about HX's? dont do it dude. too small!
Old May 15, 2008 | 07:38 AM
mahout's Avatar
Tires "don't sit straight"? The rest of these posters are correct. SOMETHING HAS TO BE DISCARDED!. Any tire that doesn't sit straight on the rim is mounted badly, is deformed, or the rim is bent. Either the tires or wheels are trash.
PS I have seen tires mounted with more than the bead buried in the rim resulting in tires twisted on the rim. So it isn't impossible. But more than likely the rim is bent if the tire 'wobbles' when turned on a true axle.
SilverEX15
May 16, 2017 10:02 AM
JDMskier
Ohio Community
Mar 13, 2017 09:09 PM
SilverEX15
15
Mar 18, 2015 01:04 PM
Tk3
Oct 13, 2012 02:45 PM
robothebobo
Jan 5, 2010 11:42 AM
