D15 sleeving
Old Aug 9, 2005 | 03:38 PM
Majorly Confused
Guest
Posts: n/a
D15 sleeving
Where can I get my D15 block sleeved (iron sleeves) affordably?
Old Aug 9, 2005 | 04:30 PM
Jason
Guest
Posts: n/a
Re: D15 sleeving
In article <Xns96AD7C550BDECdrtr@216.196.97.131>, Majorly Confused
You should call these companies and see if they can help you. I know that
they all make pistons but don't know if they have the other items that you
need:
Mahle 888-255-1942
CP 949-576-9000
Endyn 817-924-9334
JE 714-898-9763
Toda 714-327-0181
Hytech 949-581-2181
NEWSGROUP SUBSCRIBERS MOTTO
We respect those subscribers that ask for advice or provide advice.
We do NOT respect the subscribers that enjoy criticizing people.
Old Aug 9, 2005 | 11:30 PM
jim beam
Guest
Posts: n/a
Re: D15 sleeving
you're confused? not as confused as me! why would you want to spend a
fortune trying to re-sleeve a d15 block when you can get a whole one in
good condition from a junk yard for practically nothing? makes no
economic sense.
Old Aug 10, 2005 | 01:30 AM
Majorly Confused
Guest
Posts: n/a
Re: D15 sleeving
jim beam <nospam@example.net> wrote in news:TJCdnZ2dnZ1kC7HinZ2dnbPzZN-
dnZ2dRVn-z52dnZ0@speakeasy.net:
> economic sense.
Stronger sleeves = more boost tolerance... As to why I want to build a
motor like this with a D15 block is just because I'm lazy :p and I already
have two D15's on hand
Old Aug 10, 2005 | 09:40 AM
jim beam
Guest
Posts: n/a
Re: D15 sleeving
>>economic sense.
you want to boost a d15??? dude, sleeve strength is the least of your
problems.
what you're really trying to do is make sure the sleeves don't move
around - just replacing them won't do that. the "fix" is a block insert
or "posting". if you're serious about "boost", you need to go to a
b-series engine - aftermarket parts are available for those - not so
much with the d-series.
Old Aug 10, 2005 | 06:31 PM
Majorly Confused
Guest
Posts: n/a
Re: D15 sleeving
news:j82dnSDEmv9AYGTfRVn-3Q@speakeasy.net:
>> news:TJCdnZ2dnZ1kC7HinZ2dnbPzZN- dnZ2dRVn-z52dnZ0@speakeasy.net:
>>>a fortune trying to re-sleeve a d15 block when you can get a whole
>>>one in good condition from a junk yard for practically nothing?
>>>makes no economic sense.
>> a motor like this with a D15 block is just because I'm lazy :p and I
>> already have two D15's on hand
> problems.
> insert or "posting". if you're serious about "boost", you need to go
> to a b-series engine - aftermarket parts are available for those - not
> so much with the d-series.
I can get just about as many perf parts for a D series as with a B
series, although there are a bit more for the B series I know. But
purchasing a B16A would cost me around 2k plus mounts plus ECU, etc...
And the D series is a little simpler design.
Old Aug 10, 2005 | 11:36 PM
jim beam
Guest
Posts: n/a
Re: D15 sleeving
>>problems.
http://nippon-motors.com/honda.htm
b16a1, $695. unless you own a machine shop, you probably won't
re-sleeve a d15 for less than that.
Old Aug 11, 2005 | 01:32 PM
h24
Guest
Posts: n/a
Re: D15 sleeving
if you want it done right
R&D dyno 310.516.1003 darren
AEBS 858.693.3200 ben
ARI 561.746.6543 bob
Sparky Spartacus
Sep 28, 2005 07:18 AM
TeGGeR®
Sep 16, 2005 11:30 AM
Shawn McClelland
May 4, 2005 04:44 PM
TWW
May 4, 2005 11:16 AM
TeGGer®
