Sponsored by:
Sponsored by: CARiD
Lowering my Fit
Old May 31, 2008 | 06:39 PM
pcs0snq's Avatar
Lowering my Fit
I did search but could not find this detail
I'd like to lower my Stock Fit Sport for better Eco and looks.
I this a matter of new springs?
Do you have to get the car re aligned when you do this?
Based on my goals, any suggested parts (Vendor and part numbers) and how much should I lower it?
thanks in advance
Old May 31, 2008 | 06:44 PM
Fitcapo's Avatar
I think you can get coilovers or aftermarket springs either or. I am not sure if you would have to get the car realigned.
Old May 31, 2008 | 08:20 PM
m-man@sbcglobal.net's Avatar
you will need new springs and shocks, there are several kits out there already (check out the suspension fourm)
anytime you change the ride height of a vehicle you must align it,
in our case you will only need to do the front end, as the rear is a solid axle, which is not affected with ride height change,
i do not know if you will need a camber kit,
some one that has lowered the car will know
sometimes when you lower, you are unable to bring the car back into alignment with the stock adjments, a camber kit allows you to align the car
Old May 31, 2008 | 11:34 PM
henryd1981's Avatar
Got the Eibach ProKit on my car, and I still have the stock shocks. Got the alignment done a week after, and my car drives great!
Old Jun 1, 2008 | 12:16 AM
solbrothers's Avatar
had the skunk2 springs. great drop and made the car look great. now im on skunk2 coilovers. awesome product. if you're going for looks, go with springs. if you are into spirited driving, get coilovers.
Old Jun 1, 2008 | 12:25 PM
Mdelro1's Avatar
you did a search and couldn't find anything on lowering your car?! geez there is a seperate section on suspension like 5 down from this one.
AKSnowman
Mar 15, 2013 01:37 PM
ModR
25
Sep 3, 2012 11:09 PM
GodSpeed
Apr 5, 2009 09:04 AM
jadie
Oct 17, 2008 11:28 AM
gelick1904
Sep 11, 2008 02:31 AM
