Easy test for worn rings
Old Aug 19, 2005 | 04:34 PM
Jason
Guest
Posts: n/a
I was taughtthat the easiest way to determine if
an engine had worn rings was
to do a compression check.
While reading a Tom and Ray column in the local newspaper, I learned
an even easier method of checking for worn rings.
I now quote from the last portion of the column:
Tom: However, what you CAN tell by removing the oil
cap [while the engine is running] is whether the
car has excessive blowby. Blowby is created when
the rings wear out, and lots of combustion gasses
sneak by the rings and into the crackcase, where
the oil is stored.
Ray: If there is more combustion gasses in the
crankcase than the ventilation system can expel,
pressure builds up in there. When you remove the
oil cap, you might see smoke coming out.
Tom: That'd be a sure sign that you'd want to
avoid buying that car.
My comment: A compression check is far superior to
the easy test mentioned above. It's my guess that if
the rings were only slighltly worn--that you would
not see any smoke when you removed the oil cap.
NEWSGROUP SUBSCRIBERS MOTTO
We respect those subscribers that ask for advice or provide advice.
We do NOT respect the subscribers that enjoy criticizing people.
gkitf16
Sep 23, 2015 03:45 AM
richsfit
Nov 7, 2012 06:10 PM
turbodig
May 9, 2010 12:08 PM
zetaproducts.net
Zeta Products.net
17
Jul 28, 2009 12:36 PM
DVFlyer
May 21, 2008 12:12 AM
