Anyone have pics of foglight bulb install?
Old Jun 22, 2008 | 04:30 PM
trancedsailor's Avatar
I can't for the life of me figure out how to take the old bulb out. I did what the manual said and squeezed the connector to unlock the tab. Sliding it out afterwards is not working. Either I'm weak or something else is going on, cuz I strained pretty damn hard to pull it out. Anyone have any suggestions because I got pretty pissed and almost broke the entire housing
Old Jun 22, 2008 | 07:58 PM
azncarbos's Avatar
You lift it up from the inside of the plug and it will come off....sorry no picture.....
Old Jun 22, 2008 | 08:00 PM
azncarbos's Avatar
wait nvm you are trying to take out the bulb.....turn it counter clock wise and it will come out... hope that help!!!!
Old Jun 22, 2008 | 11:41 PM
Sugarphreak's Avatar
Push My Button
If you have the screws that hold it in place out and it is just hanging there the easiest way to disconnect them is with a flathead screwdriver. You have to slide it into that connector slot and it pushes down the tab.
The bulb itself is easy, just turn it and it pops out.
Old Jun 23, 2008 | 09:01 AM
doubler2k's Avatar
You have to turn the bulb clockwise and it should pull straight out. It took me a while to figure it out as well, for some reason my manual didn't have instructions.
Old Jun 23, 2008 | 12:10 PM
okay but I can't pull the bulb out til I take the connector off and that's what is giving me trouble!
Old Jun 23, 2008 | 12:52 PM
doubler2k's Avatar
Hmm not sure then, I pushed in the connector tab and just pulled down, it came off rather easy, remember the h11 bulb has a L shape so you dont pull straight back.
Old Jun 23, 2008 | 02:09 PM
JDMchris.com's Avatar
I run THIS
you can remove the bulb from the housing without disconnecting the harness. Just turn it pull out then you can easily use 2 hands to disconnect the harness.
Old Jun 23, 2008 | 03:28 PM
thanks Chris I'll try that in a little bit!
Old Jun 23, 2008 | 03:33 PM
koolkevin1107's Avatar
actually... if u have never removed the foglight bulbs before, it's REALLY hard. I think ur just weak (no offense) cuz the first time i unplugged my bulb from the harness, WOWWW was it really hard. Just keep attempting it, it'll unclip. Don't remove the bulb from the housing first, ur risking touching the bulb and burning it out, thus wasting a perfectly good bulb. Just try 2 unplug the bulb from the harness while it's still in the housing.
Old Jun 23, 2008 | 03:43 PM
I tried dude, seriously I used every ounce of strength in my body, it just wouldnt come off the damn thing. I'm gonna turn the bulb and pull that out so at least I can put the housing down and focus my strength more on pulling it out of the plug connector thingy
Old Jun 23, 2008 | 07:21 PM
ghibli99's Avatar
Man, if you're having a tough time w/ the fogs, you're gonna have a blast replacing the front 194 parking wedges.
-Mike
Old Jun 24, 2008 | 12:19 AM
tommyinsane's Avatar
Look for the tab. The tab clips the harness in place. If you are doing it rite, the harness really pops rite off. You don't need to force it really hard.
Old Jun 24, 2008 | 11:06 AM
Rod2Rice's Avatar
If you touch the bulb by accident it is not ruined. Clean it off with a rag and some isopropyl alcohol. The oil from your fingers if left on the bulb will cause a hotspot on the glass and premature failure. Clean it right and you will be fine if it gets touched.
Old Jun 24, 2008 | 06:03 PM
okay finally got it done. I found the tab that made it come RIGHT off. I am kicking myself in the ass for making it seem harder than it was ;/
Old Jun 24, 2008 | 06:29 PM
doubler2k's Avatar
cool! now please don't try to change your oil cause the steering wheel might fall off or something! j/k!
get_FIT
Apr 19, 2011 05:27 PM
drock305
Feb 9, 2010 08:06 PM
xonexlifex
Nov 26, 2008 06:45 PM
ericman20
Jul 18, 2008 01:54 AM
Luichenwai
Mar 13, 2007 12:50 AM
