quick release?
Old Jun 29, 2008 | 12:46 AM
jani88's Avatar
quick release?
okay i personaly have never had a quick release steering wheel, and i got a few questins.
1. i know it will disable the drivers airbag, will it also disable the passanger side one?
2. will it disable the side curtan airbags?
3. any way to get rid of the SRS light? or just take the bulb out of the cluster?
veryyy interested in buying one, thanks
Old Jun 29, 2008 | 01:16 AM
kelsodeez's Avatar
UNBANABLE
the only airbag it will disable is the one you unplug. there is a way to wire up the airbag wiring harness to override the light but im not sure how to do it and i havent come across anyone that knows how to so the easiest thing to do is take apart your gauge cluster and pop the little bulb out.
Old Jun 29, 2008 | 01:34 AM
jani88's Avatar
oh alright
bty what size wheel do you got? and do you know the oem steering wheel size?
i was lookin at the woodgrain nardi one, i believe its 350mm
Old Jun 29, 2008 | 01:43 AM
kelsodeez's Avatar
UNBANABLE
yea i have the nardi deep corn 330mm and i love it. i have no idea what size the stock wheel is but its huge!
Old Jun 29, 2008 | 01:58 AM
Robywolf's Avatar
If any there is anything wrong with the SRS system the light will come on, if the light is on the entire system is Diabled no if's, and's, or but's about it. You would have to rewire the whole system to bypass the steering wheel. Good luck with that it only takes a small charge to set off the whole sytem, so if you feel lucky go for it LMAO, good luck.
bosshogg
Jul 14, 2013 10:16 PM
jiko
Mar 20, 2013 02:06 AM
bcr888
Jul 29, 2011 02:29 PM
bcr888
May 15, 2009 10:47 AM
bosshogg
Aug 31, 2008 05:17 AM
