Aftermarket Steering Wheel for GE SRS Bypass
Old Oct 27, 2010 | 10:21 PM
bcr888's Avatar
Hi,
Has anyone tried to bypass the SRS and install aftermarket steering wheel? I was wondering if the older method of bypassing using a 2 ohm resitor would work on our GEs. I'd like to have a cheaper alternative other than buying a worksbell adapter.
HOW TO: Bypass SRS for Aftermarket Wheel - Honda-Tech
Also, do GEs have a MES plug just like older hondas for resetting SRS?
TIA.
Old Dec 20, 2010 | 09:42 PM
555sexydrive's Avatar
I've got an aftermarket wheel and both driver and passenger bags removed, obviously the driver with the wheel. :P I am using a Works Bell J's edition quick release and it comes with the necessary resistors for both driver and passenger harness plugs to keep the SRS light from lighting up.
So I would imagine using the resistor would work just fine since that is what comes with the WB. Not sure about the resetting of the SRS with the MES plug. My passenger side resistor either came loose before or something and the SRS light lit up, turning off the car and back on, cleared the light after reseating the resistor. I have noticed if I move the vehicle before the SRS light goes out upon startup, it will stay on. Then need to cut power completely and the light resets.
Old Jul 29, 2011 | 02:29 PM
RetroAttack's Avatar
I have been wondering if the resistor would work aswell
I know i want to buy an aftermarket steering wheel but i dont want to buy the works bell hub really just because it has the srs delete built in.
jiko
Mar 20, 2013 02:06 AM
hondafitblue
15
Feb 9, 2010 12:53 AM
bcr888
May 15, 2009 10:47 AM
jani88
Jun 29, 2008 01:58 AM
kelsodeez
44
May 30, 2008 07:58 PM
