I LOVE the fit, but I HATE it right now...
Old Jun 30, 2008 | 09:25 AM
jsmooney's Avatar
So, I posted back in may about a MIL/CEL.
Cylinder 1 Misfire was the code.
So we are driving home from walmart....surprise!!!...the light comes on.
I went back to my house, searched online and it seems like I am the only one with a Fit having this problem. I did the DIY code check....71 - same code. It's running the same as before.
I have checked the connectors, coil packs, spark plugs - I've even swapped the coil packs and spark plugs around.
Last time, it just stopped acting up and ran fine. It's rather annoying...
Any ideas?
Thanks in advance!
Other than this relatively minor problem - I love the fit. Just got 35% tint all around last week I'm about to trade in the prelude for another!
Old Jun 30, 2008 | 10:31 AM
yeamans17's Avatar
So why don't you take it to the dealership. Or is it out of warranty?
Old Jun 30, 2008 | 10:37 AM
jsmooney's Avatar
Long story....
we bought it from a place that rebuilds hondas after they are "recovered"
It has almost 11,000 mi on it.
They gave us a warranty for 1 year. It was bought in April
Old Jun 30, 2008 | 11:50 AM
gimme's Avatar
Master FitFreaker
utilize the warranty that place gave you.
Old Jun 30, 2008 | 11:56 AM
jsmooney's Avatar
the place we bought it from is ~50 mi away. I was just trying to check everything i could before I go there and its some stupid connection that's loose.
I think it would be somewhat amusing (but not good at all) to roll up in there with a rod clanging around a hole in the block. The guy did say "just drive it"
Old Jul 1, 2008 | 10:20 PM
Carbuff2's Avatar
Shot in the dark, but it has happened before (on other cars):
You may have a dribbling injector. Swap #1 with another cylinder. If the misfire code follows the injector, you found it.
All cars benefit from the occasional "Italian Tuneup". Run it through the gears to redline once in a while, or maintain 4000+ RPM for a minute...the extra on-time for the injectors helps keep them clean. (And, it's FUN!)
Old Nov 17, 2008 | 06:02 PM
ikrash's Avatar
same exact problem man...ive been trying to find a solution
my car jumps a little bit when im on the throttle
and the CEL flashed a few times
i think its my coilpacks...but i really have no idea
if you found a solution...let me know
i need to get this fixed cuz its driving me crazy
Old Nov 17, 2008 | 06:42 PM
jsmooney's Avatar
okay. I thought I updated this before, but I did find a solution.
The place we bought it from didn't think anything was wrong. Finally, it messed up again and I had to drive it at least 50 mi on no more than 3 cylinders. They did what I suggested at first - replaced the computer. It's fixed and runs fine. The engine is just a little noisy....I don't know if it is an effect from this problem, or if something else affected it.
Old Nov 17, 2008 | 09:56 PM
shonda1989's Avatar
your probubly getting more noise because you have another cylinder working. How long was the cylinder not working, because if it was completely dead for more then a month of DD then i would find a replacement piston, you may even have to get a new set of pistons if they wore that un evenly. or just leave it and you wont get the full life out of the car, but by then it will be someone elses problem.
Old Nov 17, 2008 | 10:00 PM
jsmooney's Avatar
it's louder than it was new with all 4 cylinders working. chances are it will last for a long time and it's nothing too serious. if something goes wrong, I'll fix it. It's my fiancee's car.
I just got a 97 prelude sh with 205,000 mi and it's quiet....I don't thing the h22 is superior to the L15 - its a different class of motor.
Hydrogirl
Aug 18, 2023 08:03 PM
Globalksp
Jun 20, 2021 11:36 PM
gavrax
Sep 17, 2016 07:56 PM
MikeSwope
Oct 25, 2013 12:15 AM
Tuan
Oct 2, 2009 06:41 PM
