Faulty A/C
Old Jul 16, 2008 | 03:16 AM
Spooling's Avatar
Faulty A/C
Hey guys
I figured I could use some luck on here regarding my A/C issue. When I turn on my A/C I can hear the compressor fans working fine, but there is no air blowing?? What could be the problem? Fan working but no air blowing?! Mind you this is my second time I have had to use the A/C. Last time I used it was back when I first got the car last Sept.
Thanks and greatly appreciated
Old Jul 16, 2008 | 04:00 AM
doctordoom's Avatar
Supervillain
hmm, it'd probably be covered under warranty, so you should bring it to your dealer. does the fan blow air if you turn it on without a/c?
Old Jul 16, 2008 | 04:13 AM
Spooling's Avatar
No, it doesn't.
I will bring it to the dealers tomorrow. I'm worried the dealer will call void on the warrenty because of modifications... I have a Scosche radio din kit.
Old Jul 16, 2008 | 10:04 AM
seeremlive's Avatar
Since you moved the heater controlls to the new unit, I bet you didn't get something plugged in all the way or just forgot something. Pull it open and check all of the connections. I know it is a pain in the A$$ but it is the most likely way to resolve the issue.
On second thought you may be able to just drop the lower cover for the knobs and check the plugs for the fan controll. Also make sure to check the heater fan fuses. Check Fuse #5 under the hood and #10 under the dash.
Old Jul 20, 2008 | 02:09 AM
Spooling's Avatar
Update:
It was a connection issue. One of those wirings got loose and the power to the fan blower was lost. Took the car to my trusty friend's repair shop. All fixed in less than a day, 40 bucks.
Richmond Honda refused to cover it under warrenty even though I had never tempered with the A/C.
Old Jul 20, 2008 | 11:20 AM
kancerr's Avatar
congrats on gettin it fixed. boooo to richmond honda!
sdashia
Jun 19, 2019 08:17 PM
cruiserandmax
Mar 31, 2019 11:35 PM
arkansasfit
May 14, 2014 03:27 PM
SportGirl11
Jul 28, 2012 09:05 AM
alvarospatchez
Aug 18, 2010 12:25 PM
