oil level indicator check
Old Jul 18, 2008 | 04:27 PM
tk_jazz's Avatar
the oil level indicator stick, for my honda jazz 2003,
im trying to find out if i need to top up my oil by measurement of the metal stick, there are no clear marking to says minimum or maximum, unlike my previous car !
there are however twist in the rod/ stick, and two small holes about 2cm apart.
any advice if i should just top the oil up or what the recommended level is,
i dont have the owners manual so im pretty stuck,
its due for a filter and oil change, but i wanna do this myself !
Old Jul 18, 2008 | 04:49 PM
yeamans17's Avatar
The 2 holes in the dipstick are the Min and Max lines, so make sure you're in between the 2 lines, The L15 takes about 4 Qts, so if you're not running a 1.5 liter motor you should find a way to figure out how much oil it takes.
SilverEX15
Oct 26, 2017 07:44 PM
Vince_TB
Apr 25, 2014 11:58 AM
Flyboybob
Oct 2, 2013 01:25 AM
richsfit
Nov 7, 2012 06:10 PM
2Fit2
Feb 18, 2012 01:59 PM
