Wheel fitment question!
Old Jul 21, 2008 | 01:38 AM
IstayFitted's Avatar
Question Wheel fitment question!
Well, I recently purchased some 15x6.5 Sparco NS-II's wheels with a +32mm offset. The wheels came with some beefy tires (2-205/55s and 2-205/60s) but I do plan on replacing with some stock tires for the meantime. During a test fit, it seemed like the stock wheel studs were too short to barely even put on any lug nuts. The cheapo lug nuts that I had used for testing purposes didn't even fit since the lug holes are apparently smaller! In order to make these wheels fit what would you recommend I do? Do I have to buy some extended wheel studs? Also, which lug nuts are compatible with these wheels since it seems like I need some "stepped" style lug nuts? Please help b/c I would really like to put these bad boys on asap! Thanks in advance!
Here's a pic of the wheels as I prepped them for paint.
Old Jul 21, 2008 | 05:03 PM
mahout's Avatar
I believe those wheels / tires will rub at 32 mm offset.
Old Jul 21, 2008 | 05:08 PM
JDMchris.com's Avatar
I run THIS
I ran the exact same setup on my Enkei Racing S and The wheels fit on fine... You WILL rub tho.
Old Jul 21, 2008 | 06:55 PM
Thanks for the responses guys. It just seemed like I had to replace the oem wheel studs with extended ones...so any typical tuner lugs would should work fine then? Forgot to mention that I am not lowered yet so hopefully rubbing would be minimal.
Old Jul 21, 2008 | 08:19 PM
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
Theres something wrong with the hub bore or the lugs you used. The offset of wheels wont make your OEM lug studs shorter; unless you used spacers of some kind. Those wheels either werent sitting flush on the hub or the lugs you used are crap. (as you said)
Get some nice tuner lugs with locks. Kics or Rays. Something like that.
Also, if you want them on with minimal rubbing use 195/50/15's for tires. Not lowered you might not rub. Not much at least. Lowered you will as said above.
Old Jul 22, 2008 | 04:49 PM
Thanks for the response...I tried one of my friend's rays lug nuts and it didn't fit either. It looks like I will have to find some decent small diameter lug nuts.
Old Jul 22, 2008 | 05:58 PM
mahout's Avatar
1. Not all wheels have the same thickness between the base of the lubnut and the hub face. If your lugs are now too short and you have different wheels that may be the reason.
2. Many wheels need the 'tuner' lug nuts to fit inside the 'holes' to the lutbolys.. They are smaller and require a special tool (essentially a inside grooved pipe that matches the lugnuts grooves) but still need to be tightened with a torque wrench.
3. Be sure you have engagement of the lugnuts equal to the diameter of the bolt. Two or three 'turns' is not safe !
Old Jul 22, 2008 | 09:18 PM
Posts in the NUUDE
Youll probably need slim lugs. I dont know there real name, I think if you mentioned slim lugs and told whoever your problem theyll know what to do.
I know my friend Jerome has TINY lugs on his Fit. Hes on Arospeed wheels. The lugs are so slim and skinny. He cant remember where he got them though.
Nuno Quintelas
Jan 31, 2017 12:42 PM
subicraze
Jun 1, 2015 06:16 AM
annunC8
Feb 14, 2013 09:47 AM
THE_CRUCK
Jun 10, 2012 01:29 PM
Fithonda2008
Sep 18, 2008 07:46 PM
