DIY door sill **need help ><**
Old Jul 29, 2008 | 05:21 AM
hkfung513's Avatar
i just recently got a honda fit and i want to put some door sill lights..
i read the DIY's and i knoe where the wires go..
but im not sure how to hook up all 4 LED strips..
do i hook up all 8 wires to the fuse box?
from the DIY i saw in https://www.fitfreak.net/forums/fit-...ome-light.html
i can see 1 strip of LED hooking up to the 2 slots.. but wht if i want to hook up 4 strips of LED? if each strip splits into - and +... that means there would be 8 wires in total?? like 4x- and 4x+ ?? i seriously dunno wht to do.. do i just stuff 4x- in one slot and 4x+ in the other slot??
Old Jul 29, 2008 | 05:42 AM
moegenki's Avatar
You can have 2 wires coming out of the fuse box and daisy chain the led strips with quick wire taps instead of stuffing 8 wires into the harness plug. The main thing to remember is that the ground in the fuse box is switched.
Old Jul 29, 2008 | 05:44 AM
hkfung513's Avatar
uh oh~ which one is the ground? ><
Old Jul 29, 2008 | 12:40 PM
flat side of LED is always ground (-)
study here... Light-emitting diode - Wikipedia, the free encyclopedia
Old Jul 29, 2008 | 12:52 PM
koolkevin1107's Avatar
actually both of the prongs are the same thickness, however if u buy an LED, the longer prong is the positive side and the shorter one is the negative. In his case, he has a pre-wired set of led's in which the black wire is the ground and the red wire is the positive.
Old Jul 29, 2008 | 02:20 PM
moegenki's Avatar
If you're referring to the harness plug if I remember correctly the bottom left wire is always hot and the upper right is the switched ground. Do double check in that DIY though.
Old Jul 29, 2008 | 03:08 PM
hkfung513's Avatar
so can u guys gimme a picture of where the black wire should go and where the red wire should go?? n also.. i think i have to solder the wires to the LED? am i correct?
in the DIY.. he didnt mention anything abt switching the ground tho.. in the original picture.. a wire was stuffed in the bottom left corner.. and a wire is stuffed in the top right corner..
Old Jul 29, 2008 | 03:42 PM
moegenki's Avatar
In that post it says:
"The green w/ red striped wire in the upper right of the plug is the ground. THAT is the spot that is switched on and off along with your dome light.
The plug in the lower left corner of the switch is an always on power.
So red goes to the always on positive and the black goes on the ground.
There are led strips that already have wiring. All that's left is for you to wire it up to the car. Check out oznium.com
Old Aug 11, 2008 | 11:52 AM
Fit of RAGE's Avatar
Honestly, if you are not good with electronics, get it done profesionally. It's not worth screwing up the car.
PS: why am i labeled as"GD3-L15A"??????
Old Aug 11, 2008 | 12:44 PM
saiko's Avatar
Avid FitFreak Poster
try soldering all of the together and connecting them to one or solder two of the together so only 2 go into the fuse box.
You'll loose some power but it may fit better.
NLEPATHY
Jul 28, 2016 02:49 PM
sriracha
May 22, 2014 09:04 PM
Santiad
Apr 18, 2013 01:50 PM
omfgitshimm
May 5, 2009 03:13 PM
B-Fit
Jul 19, 2008 11:02 AM
