94 civic - wouldn't start til turned steering wheel
Old Sep 20, 2005 | 12:37 AM
Rocky
Guest
Posts: n/a
ran fine on the way to work.
at lunch time, crank, but didn't even come close to catching.
not flooded
when I turned the steering wheel, then it started
any suggestions what to look for?
176,000 us miles, 5 speed.
jim beam
Guest
Posts: n/a
Re: 94 civic - wouldn't start til turned steering wheel
> not flooded
tegger.com. main relay.
'Curly Q. Links'
Guest
Posts: n/a
> not flooded
Car warmed up inside while sitting. Smacking the dash with the key in
position II would have worked the same too. Replace or resolder the Main
relay.
'Curly'
Old Sep 20, 2005 | 08:32 AM
Remco
Guest
Posts: n/a
> not flooded
The other suggestion made (main relay) is perfectly valid but it could
also be the ignition switch.
Since it started when you turned the wheel, perhaps you jiggled
something that is making intermittent contact. I'd make sure that all
connections to it are tight.
Is it repeatable?
Remco
zeniitti
Aug 31, 2017 03:34 AM
Vash
May 26, 2010 10:44 AM
Fit2002_2008
Feb 24, 2010 12:54 AM
wannadoitmyself
Oct 5, 2005 09:34 AM
dtrejo
May 15, 2005 07:30 PM
