ECU options?
Old Aug 17, 2008 | 03:28 AM
1990hondahf's Avatar
ECU options?
What ECU options for boosting are out there? I know of emanage(blue), F-con, emanage ultimate...what others are there? Thanks.
Old Aug 17, 2008 | 11:17 PM
underdog's Avatar
aem FI/C is a piggy back option. and if you have deep enough pockets i'm sure its possible to convert to K-pro by hondata.
Old Aug 17, 2008 | 11:30 PM
I was looking at the emanage ultimate....seems to retail for around $600 or so. I just would want to get somthing that I can tune from my laptop.
also what about a s-afc?
Old Aug 18, 2008 | 09:42 AM
underdog's Avatar
s-afc has no control over ignition timing so that would be a no no for a boosted car. my tuner prefers the aem fi/c over emange ultimate(he won't touch the emanage). there is a huge debate about that online and it always appears the aem wins over the greddy. you can also get the fi/c for around $400 or less if you have connections.
Old Aug 18, 2008 | 04:57 PM
....good info, didn't know that. I see what I can find out about the AEM....TY!
also, what is it about e-manage that your tuner does not like?
Old Aug 18, 2008 | 08:15 PM
Sugarphreak's Avatar
Push My Button
The Fit seems to respond well to the E-manage Ultimate, AJR was able to get quite a bit more power out of their Turbo kit when VS using the E-manage Blue.
I even run it on my naturally aspirated Fit, works wonders.
Old Aug 18, 2008 | 09:51 PM
underdog's Avatar
i'm not sure to tell you the truth. all I do know is he says its crap and he won't touch it so i'll go with his word and stick with the aem. he's tuned everything from his wifes DD to a 1200hp mustang. so I trust him. he made 631whp on my cousins car vs's the 554whp done by a well known local tuner. same setup(with very minor changes) not to mention the driveabality was a million times better. we always had hot restart issues, car dieing when comming to a stop, bucking and surging at light throttle, ect.... now it honestly drives almost good as stock(with the exception of the twin disc clutch) with 1600cc injectors on a 2.0l honda on E85. just looking at the maps between his tune and the previous tuners looks soo much cleaner.
Old Aug 18, 2008 | 11:24 PM
leonine's Avatar
i was considering aem but the F/IC only retards ignition timing. It doens't advance it. not sure what the stock ignition map is but i'm sure it is pretty conservative.
Old Aug 18, 2008 | 11:29 PM
underdog's Avatar
this is true. but being boosted I honestly doubt there is anywhere in the map you would be adding timing???
Old Aug 19, 2008 | 02:45 PM
FYI about the AEM F/IC....they don't have one for the fit yet(I called them) but.... I did find a poster on their forum who made one work. : Please help me find TPS wire for 07 honda fit (PIC inside)
Old Aug 19, 2008 | 04:18 PM
leonine's Avatar
that person is a member of this forum. looks like the wiring (according to him) is the same as the 06-07 s2k with the exception of the TPS signal. that connection was answered in the link you provided. i downloaded the s2k wiring diagram and compared it to the pinouts he provided in the link you attached and it looks to be correct.
so that is a big plus imo having a wiring diagram to reference makes the install easier.
TPColgett
Oct 10, 2012 07:21 PM
arnshrty
Mar 27, 2012 06:17 PM
manuelgbn
Feb 16, 2011 02:56 PM
im the fit
Dec 26, 2009 05:44 AM
Feinkosta
Feb 14, 2009 01:01 AM
