DIY - 06+ Civic Si/Type R Shift boot into Fit
Old Aug 17, 2008 | 12:25 PM
JDMchris.com's Avatar
I run THIS
Disclaimer: The following is provided as a GUIDE ONLY, and neither myself, nor FITFREAK.NET endorse, recommend, encourage nor take any responsibility for the outcome of someone else doing the following. You follow these steps at your own risk!
Parts needed:
Phillips screw Driver
Drill
4 screws
Si or Type R Shift boot
Step 1.
Remove Console
Step 2.
Flip console over and remove the 3 screws to free the center ring.
Step 3.
Dremel out the inner ring
Step 4.
Mock up the Shift boot and drill your new holes to screw it on.
Step 5.
Screw it in.
Step 6.
Re install and enjoy!
Old Aug 17, 2008 | 12:46 PM
08fithappy's Avatar
Good write up
Old Aug 17, 2008 | 06:41 PM
petwhookie's Avatar
whats the reason for drilling out the inner ring?
Old Aug 17, 2008 | 08:26 PM
dagul's Avatar
Looks like the boot won't sit flush with the outer ring if you don't dremel the inner ring.
Old Aug 17, 2008 | 09:35 PM
jvm051's Avatar
Nice writeup. Does the rubber grommit that is right below the shift know come with the Si boot? Also do the screws come with it, or did you just use off the shelf screws? And how big were they so it did not drill the screws out the top of the silver ring.
Old Aug 17, 2008 | 10:14 PM
I run THIS
yes, the inner ring comes out or you will have a gap.
are you talking about the thing that doesnt allow the shift boot go down too low? Yea it comes with it. I just used screws that I had laying around... They can go through the ring a little because you still dont seem them when installed.
Old Aug 18, 2008 | 01:36 AM
Kyle is raaddd's Avatar
Master FitFaker. CHEA!
this is a great write up chris
+rep
when i get my fit i will definitely do this
Old Aug 21, 2008 | 07:38 PM
goodyonsen's Avatar
can i order one of these online? an 08 one?
Old Aug 21, 2008 | 08:24 PM
redrumm's Avatar
nice right up.
i like the all black intstead of the red stitch. it would go better with my 99-00 SI shift knob
what year is that boot from?
Old Aug 21, 2008 | 08:55 PM
I run THIS
its from a 06-07 Si
Old Aug 21, 2008 | 09:35 PM
redrumm's Avatar
its from a 06-07 Si
HA nice i just saw that in the title
Old Aug 27, 2008 | 02:40 PM
Pepperinyoureye's Avatar
just finished mine,ill try to get pics soon
Old Aug 28, 2008 | 11:04 PM
jvm051's Avatar
Got my boot yesterday (went with the red stitching) and will be installing this weekend. Stupid me, I busted the 2 clips on the front of the console, and the damm piece under the e-brake broke as well. I'm doing a h-fit short throw shifter, skunk2 knob and xm tuner at the same time, so hopefully everything else goes well. Will post pics once completed
Old Sep 6, 2008 | 04:40 PM
Heres mine...
Old Sep 6, 2008 | 04:58 PM
Evotech8's Avatar
^ Is there a reason the boot is sagging below the knob??
Old Sep 18, 2008 | 10:39 PM
gawa's Avatar
Great DIY. Thanks for writing this up jdmchris.
Old Jan 15, 2009 | 01:58 PM
trancedsailor's Avatar
damn this looks like a good option. I want to do this but I don't have a dremel ;/
Old Jan 15, 2009 | 02:02 PM
SFactor2's Avatar
From: Negative Repland (exiled by fragile ego's and "can't handle the truth" babies) LMFAO ;P
Parts needed:
Drill
4 screws
Step 1.
Remove Console
Step 2.
Step 3.
Step 4.
Step 5.
Screw it in.
Step 6.
nice WRITE-UP but....next time u take any photos plz plz plz have the light source i.e. the place with the brighter light BEHIND (should face indoors with outside behind u) thx
btw nice bootie
Old Jun 3, 2010 | 05:28 AM
YA2_user_GD3's Avatar
did you guys all dremel out the inner ring?
Old Jun 3, 2010 | 10:21 AM
I run THIS
the inner ring must come out for it to look clean.
