Anyone else have an oil pressure gauge..
Old Aug 19, 2008 | 12:43 PM
explosivpotato's Avatar
..and notice the beastly oil pressures this motor likes? Mine seems to like 70 psi while cruising (and sometimes over 100 when the motor is cool!)
I had an oil pressure gauge on my old Mazda and it never liked anything over 55 or so - even when I was wringing it. I'm pretty sure that old motor would have sh!t itself if it ever saw 100 psi..
Old Aug 19, 2008 | 02:58 PM
feddup's Avatar
scanguage?
I assume you're using a scanguage to get these numbers?
Old Aug 19, 2008 | 06:41 PM
No, the scangauge can only display parameters that the ECU can monitor. The only pressure gauge the ECU could see would be the sub-5psi dummy switch.
I have a pair of Prosport gauges installed using their oil filter sandwich plate setup. It monitors oil pressure and temperature coming out of the oil filter.
Wolfgang Kluge
Sep 14, 2017 09:21 AM
CityHunter
Oct 25, 2012 01:28 AM
2007FitBLK
Sep 10, 2012 01:58 PM
Previc93
Jun 25, 2010 09:29 AM
KnifeEdge_2K1
Toronto Community
Apr 13, 2007 02:27 AM
